Subject: Re: CNC engraving on wood
3/3/15
Alex Member
Website: http://atelierrolando.com
Hi ,
I would appreciate some suggestions regarding small size CNC machine to engrave small logos (6 x 6mm) on curved surface, in wood. Most of table top engravers have a flat bed. I need to engrave objects 3" high, slightly curved.
Any suggestions in the range of $3,000 price ?
3/4/15       #2: CNC engraving on wood ...
jerry Member
I see there is a used Shopbot desktop for sale on the Lets talk shopbot forum. It is a little more than $3000 but you do get extras that you would have to buy later.
Shopbot desktop
3/4/15       #3: CNC engraving on wood ...
B.H. Davis Member
The flat bed is not an issue. You'll design the curved surface with your CAD or CAM software. Any small CNC should do the job.
Your question should actually be "what software do I get to to this task?" I suspect you can accomplish it with most of the CAM packages out there. I use Enroute and that will do it for you.
3/4/15       #4: CNC engraving on wood ...
Chuck Hicks  Member
The Camaster is a great machine also.
3/7/15       #5: CNC engraving on wood ...
Don't you have to add 1 zero and a little more to get a Camaster? He's looking for a little bench top. Probotix looks like a nice little machine. Assembled here in Peoria, IL
Probotix
3/8/15       #6: CNC engraving on wood ...
jerry Member
Camaster does make a small unit but it is 3 times more than he wants to spend.
