Subject: Re: Pen attachments for CNC
4/18/15
Richard
Hello All,
Just wondering if anyone has experience using the following marker system or something similar?
http://www.widgetworksunlimited.com/CNC_Plotter_Pen_Bit_Thick_Line_p/c
nc-pltr_pen_thick.htm
Just looking for some feedback of how they perform in the real world. I am thinking it maybe a simple alternative to labeling by hand which can be problematic with dust.
Thanks in advance.
Richard
http://www.widgetworksunlimited.com/CNC_Plotter_Pen_Bit_Thick_Line_p/cnc-pltr_pen_thick.htm
4/18/15       #2: Pen attachments for CNC ...
jerry Member
I have a set and they work as advertised.
4/18/15       #3: Pen attachments for CNC ...
B.H. Davis Member
I also have a set and although we don't use them often the do work as advertised.
Our only problem is that we use them so seldom that the miniature markers tend to dry up.
4/18/15       #4: Pen attachments for CNC ...
Richard
B.H. Davis,
When you are not using these markers what do you use for marking parts?
Also why do you use them so infrequently?
Just trying to figure out the best solution.
Thanks.
Richard
4/19/15       #5: Pen attachments for CNC ...
B.H. Davis Member
Richard,
We do radius mouldings so there aren't a lot of cabinet parts around to be marked. In our system each moulding has its own stack of parts and there are several at a time as vs. hundreds of cabinet parts. Labeling parts does not come into play.
We use a Dymo label maker to make the identification labels that go on the back of all the completed mouldings. These are generated automatically when we do our layout sheet for each moulding in MS-Excel.
We do a fair amount of drawing on the CNC but it is done with large magic markers in a holder I built years ago. I bought the set of fine point markers for when we might need a finer detail than we get with the standard Mark-A-Lot markers. That doesn't happen very often.
4/19/15       #6: Pen attachments for CNC ...
james mcgrew
here is another one proved popular.
View higher quality, full size image (1293 X 599)
http://http://cosmos-industrial.com/index.php?main_page=index&cPath=3
4/19/15       #7: Pen attachments for CNC ...
Richard
Hello James,
These look interesting, I like the fact that they can be replaced with regular sharpies. The pencil attachment would be great for veneer parts.
Do you use these?
Richard
4/19/15       #8: Pen attachments for CNC ...
james mcgrew Member
I have one and have yet to need it,, there is a discussion on them on Camheads forum,
http://www.camheads.org/showthread.php?t=6015
If you want to do Veneer you may like the Donek Knife,, I have used it with some really good sucess
Donek Tools
4/19/15       #9: Pen attachments for CNC ...
james mcgrew Member
This is one Cute tool !
