Subject: Re: CNC Electro-Spindle Tool Sticking - HSK
10/13/15
Jon Member
We have a CNC with a HSK type Electrospindle.
The tool gets stuck now daily - quite often but besides this the machine is generally fine.
Does anyone know what the problem may be or if we need to look at a certain area to find a problem sensor and or adjust something.
The Technicians in Sydney don't know.
10/14/15       #2: CNC Electro-Spindle Tool Sticking - ...
Danny Member
G'day Jon
With several Biesses over the years, I've had this problem also. What I did on our Rover 23Rs was not too hard. What machine is it on and do you have an exploded spare parts diagram ?? There is a plate under the piston that it pushes against and releases the collet. Over the years it wears and as it does, it doesn't have enough travel to push the tool away from the taper to release it. It just sits there hissing air and then times out. I just turned it over and it worked like new with a positive solid clunk every time it releases the tool. I guess one day, if it starts doing it again, I'd have to make a new part of weld up the worn area. If you are semi competent with mechanical things, it's not that complicated. I'm in Sydney too. What technicians did you consult ??
Danny
10/14/15       #3: CNC Electro-Spindle Tool Sticking - ...
Jon Member
Hey Danny,
Thanks for the reply
We have a Morbidelli. We originally bought it from an reller that has lost the selling rights. Gabbet currently have the contacts but we done have a good contact there - they did a health check on our machine last year and rendered it non operational for 8 days - then never came back. (it was working before they got here).
So we therefore try to solution it ourselves.
Got the manual but I am not real mechanical but I cant find an exploded electrospindle diagram - where is the plate exactly within the spinde?
10/14/15       #4: CNC Electro-Spindle Tool Sticking - ...
Jon Member
We have a HSD SPindle From SCM
10/14/15       #5: CNC Electro-Spindle Tool Sticking - ...
cabinetmaker
Before anything else, make sure the "OUTSIDE" of the tool holder and flat mating surface of the electro spindle is lubricated with something like Lusin or a dry lube. The fingers of the electro spindle need its own lubrication, but that may not be be your immediate problem,
We lube the tool holders twice a week with the dry lube and the bottom plate of the electro spindle where the tool holder meets spindle and all the sticking went away. Just spray all of the tool holders and wipe them down. We spray the rag and wipe the flat part of the spindle.
For the fingers turn the machine to manual, and eject the tool holder manually, while pushing the manualy release the fingers will be exposed. using paste grease for this, make sure you are using what is spec'd, get a stiff nylon brush and apply a small amount of grease to the fingers, and work it in. Press and release the fingers repeatedly.
10/14/15       #6: CNC Electro-Spindle Tool Sticking - ...
Maurice Phelps
Website: http://www.mcpservice.com
Give Atlanta Spindle a call....they do most repairs for SCM spindles, they maybe able to tell you wants wrong on the phone...
678-225-7855 speak to Harry, tell him what you have
10/14/15       #7: CNC Electro-Spindle Tool Sticking - ...
Danny Member
Jon,
I'll see if I can find our exploded diagram but I can't do it till next week.
Danny
10/14/15       #8: CNC Electro-Spindle Tool Sticking - ...
Jon Member
Thanks Danny
Much Appreciated
10/15/15       #11: CNC Electro-Spindle Tool Sticking - ...
Rob
Try doing the proper spindle maintenance, the pdf shows the parts numbers for appropriate lubricants. The maintenance should be done every one to to weeks. Drawings for the spindle are proprietary, and will be extremely difficult to get.
HSK_maintenance.pdf
10/15/15       #12: CNC Electro-Spindle Tool Sticking - ...
Have you been cleaning the spindle? That is step one.
10/15/15       #14: CNC Electro-Spindle Tool Sticking - ...
Jon Member
We do clean the Spindle and have done from day 1 - Religiously - so to Bill that is a yes (at least 3 times a day).
We are Following that cleaning and maintenance guide Thanks Rob - Our version is in Black and White but nice to know we have the correct maintenance sheets.
We were told by the Sydney Tech to flush out the spindle with WD40 to get any excess dust out - we were already having problems before we tried this.
Just now though - reverted back to the method attached by rob but no love yet.
10/15/15       #15: CNC Electro-Spindle Tool Sticking - ...
Danny Member
Just curious Jon, what do you do to get the tool out at the moment ?? I always had to give the toolholder a little tap with a hammer to get it to let go.
Danny
10/16/15       #16: CNC Electro-Spindle Tool Sticking - ...
Jon Member
Hi Danny
We set the manual release and press the remote whilst we are at the tool.
Sometimes (but rarely) the tool drops out but most times we just Downwards tap on the tool with a rubber mallet and it comes out.
Jon
10/26/15       #17: CNC Electro-Spindle Tool Sticking - ...
Mike McClaran
Oh boy, it seems you guys need a little HSK101 along with HSD101.
1. Do you hear the valve trying to spit out the tool when pressing the manual tool release button?
2. While holding the release button a steel hammer tap to the side of the HSK will pop the tool out.
3. To prevent this from happening again you need to use LusinG31 spray on the mating surface of the "HSK cone.
4. Do not ever use WD40 on an HSD motor.
5There is also Metaflux paste you should be applying to the draw bar when pressing the tool release button.
At BVC we supply both the G31 spray as well as the Metaflux paste. 909 606-0140
http://www.greenbvc.com
10/26/15       #18: CNC Electro-Spindle Tool Sticking - ...
Jon Member
Hi Mike McClaran,
Mate - thanks so much for the info.
I am not a machinist by trade but I do have to work with them.
In Sydney Australia, it seems that no-one (from a technicians perspective) really understands these machines.
We are quite literally fumbling through problems.
All we have done is follow the guidelines given to us which I suspected were wrong.
I reverted to Lusin after much online reading and we still have a bit of an issue (not as much) so I hope it will go away as the WD comes out.
Is the Metaflux paste available in Australia?
10/26/15       #19: CNC Electro-Spindle Tool Sticking - ...
Mike McClaran
Website: http://www.greenbvc.com
Likely not available in your country and if so probably very expensive. We ship to Australia all the time. We can even go US mail if you want. Probably 20 US dollars to get it to you. Or 100 if you find it there. Buy some Better Vacuum Cups and I will throw in the HSKG31 and Metaflux paste for free.
10/27/15       #20: CNC Electro-Spindle Tool Sticking - ...
cabinetmaker
Jon
You should not have to rap the tool holder with a mallet to eject the tool from the spindle. It should come right out with the push of the spindle release button.
One of the tricks we used was to coat the tool holder with Lusen and stick it in the electrospindle and twist it, coating the contact surface. Keep doing this until the spindle releases
10/27/15       #21: CNC Electro-Spindle Tool Sticking - ...
Rob
Check the extraction height of the drawbar. When it is fully extended, it needs to be 10.8mm +/- 0.10mm. The measurement is from the tip of the draw bar to the nose of the spindle where the hsk holder rests.
10/30/15       #22: CNC Electro-Spindle Tool Sticking - ...
Danny Member
G'day Jon,
Just curious, have you tried any of the suggested lubricants, release agents etc yet???
If so, did it fix your problem ??
The only thing to ever fix my problem was to fix the wear on the draw bar.
Danny
