Subject: Re: Cabriole Legs
Cabriole Legs
2/2/16
Gavin S
Website: http://soraghan woodworking.net
Is it possible to carve something like this on a 3 axis router ? I do have an aggregate but not sure that's going to help in this application . I was going to attempt to make one but and just do it in 4 separate programs, turning the part manually in a jig.
If someone has already gone through the aggravation to find out it's not possible can you please share ?
Thanks in advance wood web community
2/3/16       #2: Cabriole Legs ...
Robert Member
Gavin, In my experience, there’s no simple answer !....but answering by questions ?!
Essentially, I’ll say yes, but too much lies on what CAM you use ?
On a 3 axis without an Indexer, you will need help from some jigs as you will need to manually turn the machining sides ( face)
With the help of an aggregate, it may simplify some toolpath at best !
Again, more lies in ou CAM then your machine !....in respect of efficiency vs quantity output vs….if it’s possible !
To be possible, I’ll finish, yes, I’ve done it on a simple 3axis bot type ;0)!
Best of luck !
2/3/16       #3: Cabriole Legs ...
Gavin s
Robert , thank you for your reply . I am using alphacam on a biesse skill .
I have the ability to purchase a stl file to produce these so I am also worried about if the stl model I buy in can handle 3 axis and my application / machine
2/3/16       #4: Cabriole Legs ...
Robert Member
Alphacam should open the STL no problem !
But here, haven't seen the stl or original cad, so I can't really tell, but you should be able to make the toolpath out of this STL once converted by & in Alphacam !.... don't see why not !
