Subject: Re: Material suggestions for carving
9/15/16
Paul S
I have been asked to make a carving of an eagle that is eight feet wide and will be mounted outside. Material needs to be 5 to 6" thick and withstand the elements. Any thoughts of what would be the best material to use ?
9/15/16       #2: Material suggestions for carving ...
David Egnoski  Member
Website: http://www.richmondcabinet.com
Sign Foam works well, paints well, and is weather resistant. It's also light weight.
http://www.signfoam.com/
9/15/16       #3: Material suggestions for carving ...
Precision Board from Coastal Enterprises. They have different densities, depending on what finish you are looking for. It machines great.
http://precisionboard.com/
9/15/16       #4: Material suggestions for carving ...
Jerry Member
Durafoam is what I would use
9/16/16       #5: Material suggestions for carving ...
james mcgrew Member
At 5-6" thick I am sure you have worked toolpathing and machine capabilities, just a thought in deep carve and i have done a good bit of it.
i would use a 15# or better good grade of HDU suggested so far. how "outside" is it ?
The EGA is 4.5" thick cut in two slices using 3" as the base
View higher quality, full size image (1023 X 682)
View higher quality, full size image (713 X 800)
