Subject: Re: 1999 Rover NC500 importing DXF issues
1/13/17
Justin Member
This is my first post and hopefully I can clear up this issue. We have two 1998-99 Rover 20 with the Biesse NC500 software. As of now we program on NC500 and do all the CNC shapes with the basic inputs. I currently use Solidworks to design cabinets and was hoping to save the DXF's to use on the Rover.
I have found the layer naming page in the NC500 and tried saving the DXF's as R12. I tried just one layer as (0), and then also tried one scenario having a PANEL layer and ROUTER layer. I also tried saving as AutoCAD 2000 and 2004.
I tried all these with no luck, the error code is U20 Cannot read file.
If anyone could help me would be amazing.
Regards,
-Justin
1/16/17       #2: 1999 Rover NC500 importing DXF issu ...
Mark T
The drawing must be a polylines, units metric and I have found it works best to keep the layer names as simple as possible ( PNL (panel layer), RT (route layer),etc.) when specifying on the DXF set up page within the NC500 environment. I attempted to upload a screenshot of how I have it set on my offline version of the software, we will see how that goes.
Mark T
View higher quality, full size image (1824 X 1135)
1/16/17       #3: 1999 Rover NC500 importing DXF issu ...
Justin Member
Thank you for the response Mark.
I will try this tomorrow. I also made sure the origin (0,0,0) is in the bottom left hand corner of the profile.
I'm at my wits end if this doesn't work!
Regards,
-Justin
1/16/17       #4: 1999 Rover NC500 importing DXF issu ...
Dylan
Website: cnc-tool.com
also you can not use layer "0", layer names can not be more than 8 characters, or special characters, I typically put the drw in the 4th quadrant, ie neg "y" and make sure you save as R12 or earlier.
regards
dylan
