Subject: Re: inlaying plastic laminate into tables with wood edges and the offset
1/17/17
steve ayars Member
I'm looking for any information to make a insert of plastic laminate for a table with a wood edge so that the laminate will flush out with the top of the edge. we have done some stuff like this before butt I'm having a hard time with the insert matching the pocket that i made, any ideas would be helpful ,
1/18/17       #2: inlaying plastic laminate into tabl ...
Brian
So you're cutting a pocket for the laminate to set in?
If that's the case I would get out the micrometer and depth gauge set. I have done this, took a little time to run a few test parts to dial it in. I would not want to do a very big surface like a table top, I would add a wood edge to a laminated substrate.
