Subject: Re: Unloader for a cnc router
1/26/18
Anthony g g Member
Hello alll hope your doing great
I am close to closing a deal for a cnc flat table
Knowing that its x 4.2 meter adn y 2.2 meter
Working area and i will be working with double faced melamine boards
Is it a must to get an unloader ??
Hope u can help me with that
Thank you in advance
1/26/18       #2: Unloader for a cnc router ...
Bill Stanisci
It certainly is an advantage. The cycle goes, run the nest, unloader unloads the parts, load the next sheet start it running. Run secondary operations on the unloaded sheet (edgeband, bore, trim) repeat.
I don't believe I would forego the unloader.
1/26/18       #3: Unloader for a cnc router ...
a.g. Member
do u think their will be chipping edge if i unload manualy ?
1/26/18       #4: Unloader for a cnc router ...
No I am sure it will be fine hat significantly slower.
1/26/18       #5: Unloader for a cnc router ...
Lei
Website: http://www.dwd-cnc.com
I think you can consider unloader option,it is convenient for production,and it can increase your factory production ability,then you will earn money faster
1/29/18       #6: Unloader for a cnc router ...
Derrek
Ran nested base for 6 years, manually loading, unloading. 5-7 minutes to run a sheet, and 3-7 minutes a sheet to unload. Now have bieese river s with auto load unload. 45 second between sheets,
You can get by withou5 it but it definitely speeds up production. I wouldn't buy one without it today.
1/29/18       #7: Unloader for a cnc router ...
Jared Emery
There are a few low-tech alternatives for unloading your table and freeing it up to start a new sheet if you don't want to drop the cash on an automated labeler / loader / unloader. I made a 4.5' x 8.5' table that's just below the spoilboard height, with locking casters. It rolls up to the CNC, I lock the wheels, then use a 2-handled scraper to drag the parts off the spoilboard onto my parked table. Scraper: think of a "TT" shape, with the top bar hanging down to hook onto to the far edge of the cut parts. I hang onto the 8' long legs and walk backward to drag / scrape them onto the parked table. Unlock the casters, roll it out of the way, clean the table off, load a sheet, push the button, go label & band my parts. The automated option would have run me 30k for my machine. This is a $50 alternative that works nearly as well.
2/9/18       #8: Unloader for a cnc router ...
Bob
I would get the unloader if you can afford it.
If not, look closely at the gantry of the machine you are purchasing.
Our old machine was a Biesse Rover 30 and we installed the "Redneck Rake".
Very simple. We just bolted a piece of melamine on back of the gantry and used common door hinges to attach another piece of melamine to it. Just had programs end with gantry stopping at the end. Then unhooked the Rake (held in place by small rope and hook) and ran a unload program. Parts unloaded onto an unload table.
We ran 8’ pieces on a 12’ table so there was room to over shoot the end of the sheet and have room for the rake to drop down.
UBU – Ugly But Useful.
This works, but a real unloader vacuums the spoil board at the same time as unloading saving even more time.
We love our new machine with auto load/unload and conveyor :-)
Unload is much more of a timesaver than load.
