Subject: Re: Removing 5 axis spindle For repair
6/25/18
AL Member
Does anyone have any ideas or know any tech in the NY area that can help me remove my 5 axis spindle from the housing.
Its a fork design (HOMAG)
6/26/18       #2: Removing 5 axis spindle For repair ...
Bill Member
Have you called Stiles?
6/26/18       #3: Removing 5 axis spindle For repair ...
AL Member
yes
I am still waiting for a tech.
I was told about 2 weeks.
6/26/18       #4: Removing 5 axis spindle For repair ...
Nice. I shy away from stiles now. Things changed.
6/26/18       #5: Removing 5 axis spindle For repair ...
AL Member
do you know anyone or have you ever taken
out the motor.
the bearings are damaged
6/26/18       #6: Removing 5 axis spindle For repair ...
Bill Member
Sorry I don't have anything for you.
That I would imagine is complex. Putting it back on is likely harder.
6/26/18       #7: Removing 5 axis spindle For repair ...
Can't be that hard. Everything out in the open.
Get a manual.
Take lots of pics.
Make sure you block up the spindle when the last bolt comes out :)
6/27/18       #8: Removing 5 axis spindle For repair ...
Arto Member
Yeah, make somekinda bed for the spindle, manually move it so it touches the bed. Open all visible bolts and eventually you will figure out how it's built :p
6/27/18       #9: Removing 5 axis spindle For repair ...
routalot Member
You might find it quite a learning experience.I have done the job on a Thermwood and between the manual and the explanatory videos in the controller it was time consuming,but not massively difficult.Re-aligning and calibrating the spindle is vital too.
6/27/18       #10: Removing 5 axis spindle For repair ...
AL Member
Its a little bit more complicated than i thought.
Stiles do Not give any diagrams. I would understand if they don't want to give the spindle diagram but not the diagram of how its connected to the housing.
6/28/18       #11: Removing 5 axis spindle For repair ...
Rob
Is it possible that the spindle is a cartridge that removes from the housing? Eurospindle makes one similar to that, and the electrospindle just unbolts and removes from the housing. No adjustments needed after replacement. Not sure but just a thought.
6/28/18       #12: Removing 5 axis spindle For repair ...
AL Member
Yep i looked at that
Its not a cartridge style.
Taking out the bottom there is a ceramic ring
that is too risky.
7/4/18       #13: Removing 5 axis spindle For repair ...
Maurice
Being a tech that works on these machine every day, I don't even try to do spindle repairs. Once I have removed them from the machine, I ship them off for repair. TOO many things can go wrong if you don't repair them correctly and you can cause more damage then you originally started with:
Wrong bearing
Incorrect drawbar setting
Parts that aren't compatible
Not to mention, you are now liable for additional damage or injury.
You have tool spinning at 24,000 rpm do you really want to be responsible for a tool being ejected?
Where does it go?
Did you miss something that if you sent it off, the rebuilder would have done a complete rebuild and testing.
Just questions to ask
7/4/18       #14: Removing 5 axis spindle For repair ...
Al Member
The intention in not to attempt a repair.
I just wanted to remove it to send out to spindle rebuild shop.
You are correct I do understand that I cannot repair this.
3/19/19       #15: Removing 5 axis spindle For repair ...
AL Member
Update
After 3 months our spindle finally got repaired by Stiles. The tech came out to our shop to reinstall the spindle only to cause damage to the head assembly. Stiles sent us another 2 tech to take out the entire head to send for repair, After all the frustration our machine start running in mid January(7 months) all at our cost including the damage done to the head assembly and the cost of the techs.
I am trying to negotiate the cost with stiles for 2 months but I haven't got any response, they only keep sending invoices with interest. I am still hoping as a reputable company that they will do the right thing.
3/19/19       #16: Removing 5 axis spindle For repair ...
I had a similar experience, that’s why I stepped away from them.
