Subject: Re: Cutting sheets for other shops
3/25/19
Any insight as to what to charge to cut sheet parts for other shops? I just did one, and feel I'm in the ballpark at $32 sheet, but I'm curious what others charge.
I've got a buddy I used to work with back in the day that has a shop as well. I to re-draw his job in my software to get nests, (that's a different subject on what to charge on that).
The goal is to switch him over to the same software so he can just email me the job, I can nest it and if there's any problems, they/re his.
3/26/19       #2: Cutting sheets for other shops ...
ryan
We have never done this but I would only do it if you have the extra time for you to draw on the computer and extra time for the cnc and someone to run it. If I were pricing I would take the normal shop rate that you have and add 20-30% for the use of the CNC and your design time is worth more than a standard shop rate. If shops are getting you to cut for them they probably don't have time to do it and even if they did paying more having everything come off of the cnc is still cheaper than them cutting it by hand. This is if you are setup to do all operations on your cnc like shelf holes and dados stuff like that. I would give the same hourly rate for computer work but I would explain that if the job file can be sent over on your software using your parameters then it would save them the computer time.
3/26/19       #3: Cutting sheets for other shops ...
$40 a sheet 10 yrs ago for cabinet parts,fixing there program or actual programming was $75 per hour. Anything less and your just burning up you machine and bits for some one else. Its a different story if your doing this full time with very good order entry, etc, like cabparts.com or similar. Also stopping my production to run 10-20 sheets for some one else wasnt my thing. Also dont look over handling/palleting parts, takes longer than cutting the parts!
