Subject: Re: Adding a printer to label parts on a SCM Pratix S
4/3/19
JoshH
Last year we got a SCM Pratix S with a loading and unloading table, only problem is the owner never thought about getting a printer with it to label parts before they get cut. I've been spending a lot of time having to manually label parts. When I program each part I'll add text to it with the work order number and cabinet number right after (example: https://imgur.com/a/E0CGoh3 ) When the machine unloads the parts, i'll take a pic with my phone and start labeling the parts with a sharpie and tape.
What are my options for getting a printer? It would have to be compatible with SCM Pratix S and their in-house program Maestro. The owner told me he plans on having me use a program called WoodCAD Cam after we get a better labeling system in place, so it would have to be compatible with that too.
4/3/19       #3: Adding a printer to label parts on ...
ryan
What cabinet software are you running? We have the newer version of our machine and if I understand correctly the auto label can not be added if it didn't come on the machine. We use Mozaik as our design program and it prints labels for every part. We just use a cheap dymo printer hooked up to a small laptop beside the push off table. It shows a picture of the whole sheet that way it is easy to tell which part gets which label as they print out. I hope that you are not designing cabinet parts in Maestro. We have it too but its not even a good CAD program. This machines used to come with alpha cam which is now an upgrade and I wish that we had paid the extra for it to do one off stuff easier than with Maestro.
4/3/19       #4: Adding a printer to label parts on ...
ryan
Sorry it should say newer version of your machine.
Also doing it with a sharpie there's no way that you can keep up with the machine. One guy can hardly keep up with us using a label printer.
4/3/19       #5: Adding a printer to label parts on ...
JoshH
@ryan
Our drawings are designed in AutoCAD but everything that gets programmed for the Pratix is done in Maestro. I know it's not ideal but it's all I have to work with right now and it's been getting the job done. I was looking into a cheap Zebra printer similar to your dymo one. I'm just not sure if it's compatible with SCM's software.
4/8/19       #6: Adding a printer to label parts on ...
We've got a Data Max printer. It is extremely fast. Excellent print quality. It is a thermal transfer printer. Takes large rolls of labels and has been trouble free for years in all the dust and use. We print part diagrams showing banded edges, banding material, panel material, Customer & Job name & #, cabinet #, Room #, 2 bar codes for bore & insert machine and any additional notes that might be useful.
Since it has been used with several different CAD/CAM systems I doubt the printer will care which system sends it information. Some brands of label are easier to remove than others. Don't let the feed wheels on the bander run over the labels, makes them difficult to remove.
3/11/20       #7: Adding a printer to label parts on ...
Nik Member
@JoshH
Did you ever find a solution for the labeling? I'm currently doing the same thing, drawing in autocad, creating parts in maestro and hand labelling with tape and sharpie.
