Subject: Re: Omnitech-Selexx Pal- Locating Pins not coming up
8/26/20
Richard
Hello All,
I am having trouble with am Omnitech. The locating pins are no longer popping up. We recently replaced the phenolic table. Prior to that they had been working correctly. But I can't see how that would effect it. What am I missing? Any insight would be helpful.
Thank you!
8/26/20       #2: Omnitech-Selexx Pal- Locating Pins ...
pat gilbert
I would check the incoming air on the piston is not clogged
8/26/20       #3: Omnitech-Selexx Pal- Locating Pins ...
Richard
Thanks Pat.
In the end we were able to get it resolved. Turns out that we had to move the Z axis Down to 0. Then enter in an M83 code while in MDI mode. I am not 100% sure what M83 does but it did work! Apparently this is a common issue and usually occurs when resetting the Z height, which is also done through the MDI mode.
One other point is I was mistaken about the model it's an Omnitech Selexx Mate. Anyway hopefully this helps someone else!
8/27/20       #4: Omnitech-Selexx Pal- Locating Pins ...
Rob Young  Member
Richard,
The M83 command enables the pop up pins.
8/27/20       #5: Omnitech-Selexx Pal- Locating Pins ...
Richard
Thanks Rob.
That makes sense! But why does it need to be activated when the Z is at zero? And what could we need done to inadvertently turn them off? Just trying to avoid this situation going forward.
Thank you
8/28/20       #6: Omnitech-Selexx Pal- Locating Pins ...
DannyB Member
Without thinking too hard, that does seem weird.
I wonder if they just screwed up the programming.
Usually it would be the opposite - the Z axis needs to be all the way up so that the pop up pins don't accidentally smash into your spindle.
11/24/20       #8: Omnitech-Selexx Pal- Locating Pins ...
MrMelamine Member
The Locating pins will only come up when the Z axis is set to zero. From what I can figure its a matter of protecting the spindle and product off-loader from accidentally hitting the pins.
    • Better Vacuum Cups, Inc.
    • Palmetto Cabinet Doors
