Subject: Re: MDF Doors on CNC
MDF Doors on CNC
2/16/21
Brent Member
Looking at cutting MDF doors on my CNC. I'm not sure I will be making a lot of these so I am trying to find some bits that are a little more affordable than Vortex and GLCT. I saw a CMT kit that looks to only be available in Europe. Has anyone else found a set that works well? I am using Mozaik as my design program.
-Thanks
2/16/21       #3: MDF Doors on CNC ...
Why skimp on tooling with MDF. MDF is a material spawned by satan.
2/17/21       #4: MDF Doors on CNC ...
james e mcgrew  Member
Whiteside basically created the MDF (You should be using HDF) door profiles. if you are selling a quality product then Bit life and pathing are a cost of business
A cheaper grade of carbide results in less use, lesscost and less use add upt to same or less cost than the right cost to begin with.
2/17/21       #5: MDF Doors on CNC ...
Chuck Hicks Member
We can help with that. We also have the 1/8 bit used to clean up the corners
View higher quality, full size image (1126 X 446)
2/22/21       #6: MDF Doors on CNC ...
Brent Member
Has anyone used the Guhdo or Vortex shaker door bits? I am leaning towards Vortex because of their insert pricing for costs down the road.
2/22/21       #7: MDF Doors on CNC ...
I've got one vortex profile set. It's done what I need it to.
Angled inside profiles or square doors I use a mix of Amana and Vortex. Insert and solid carbide.
2/28/21       #8: MDF Doors on CNC ...
D Conti
white side carbide bits are a good starting point, they can be sharpened as well. Insert is the way to go if you are going to produce a lot of mdf doors. I myself have a few white side basic profiles for the old mdf style doors, and insert for shaker doors(we make a lot more mdf shaker doors then raised panel) Vortex, gudho, glct all make excellent insert tooling door sets. I do not think you will be dissapointed with any of them but they are pricey
    • Biesse America
    • Country Saw & Knife
    • Limtech Industries, Inc.
    • Charles G.G. Schmidt Co.
    • Palmetto Cabinet Doors
