Subject: Re: Autodesk Fusion
Autodesk Fusion
7/8/21
BH Davis  Member
Has anyone used Autodesk Fusion to create 3D drawings and then created G-code for the drawing?
Fusion is basically a metal working oriented program but as long as a post processor could be adapted to generate code for our machines perhaps it could also be used in our industry.
Thanks,
7/9/21       #2: Autodesk Fusion ...
BH,
Just for fun, I did a search on post processors for fusion. Seems there are plenty available for this industry Including Fanuc, Osai, axyz, flexicam, WoodWOP, and more. I've included the link where I read this. Not sure how any of that works with the software but that is my 2 cents after a 2 cent search.
https://cam.autodesk.com/hsmposts
7/9/21       #3: Autodesk Fusion ...
BH Davis  Member
Mike,
Yup...........also found that last night after posting this question. The two I want to experiment with are there: UCCNC and WinCNC.
I'm using UCCNC control software now but have found the WinCNC post processor works fine and is more to my liking. Of course both are set up differently for Fusion so there will be a learning curve.
Thanks,
7/10/21       #4: Autodesk Fusion ...
pat gilbert
You can do that in regular auto cad
But without software to extract the parts and orient them correctly it would be a PIA
Smarlister does this BTW
7/10/21       #5: Autodesk Fusion ...
BH Davis  Member
Pat,
If you can apply a toolpath in AutoCAD I suspect that is in the full version.....correct?
I run AutoCAD LT as that has always been more than adequate for my needs.
Thanks,
BH
7/10/21       #6: Autodesk Fusion ...
Arto Tuisku
I have used fusion 360 for a few years now with a homag machine. I use it mostly if a customer provides a 3d drawing of a complex shape or if i need to do 3d work. For the normal everyday stuff i use woodwop.
The postprocessor doesent seem to be perfect, sometimes i get errors, but have allways found workarounds.
7/11/21       #7: Autodesk Fusion ...
pat gilbert
Bernie
AutoCad is not CAM
I you only have a few parts to do it won't matter
7/11/21       #8: Autodesk Fusion ...
BH Davis  Member
Pat,
I know. However you said "that can be done in auto cad" so I thought maybe there was a CAM feature I didn't know about in the full blow program.
So what did you meant by "that can be done in auto cad" in the earlier post?
Thanks,
7/12/21       #9: Autodesk Fusion ...
Peter Matos
Been using Fusion360 for several years now both at my home shop as well as now at work on all of our CNC's. I find it very capable and I get good code without issues unless I did something wrong. Even doing a lot of 3D constant contouring and mouldings and elaborate parts etc. It has come a long way. I have even recently been doing entire room modeling in the software and creating some rather impressive 2D drawings from the 3D models as well as renderings. We use it in addition to our dedicated cabinetry software Mozaik. It is also nice to be able to import exact sized 3D models of hardware from Blum etc. and show them not only in the 3D model but also in the 2D drawings correctly. We use it even for our SLA 3D printer for prototypes of smaller parts and on our HAAS VF4 for metal/plastic parts. Personally for me it has been a big win. Especially for the price. I used to run MasterCam and Solidworks in previous shops and while those offerings are more capable in a few different areas for 99 percent of what we do both in wood and metal it works great. They even have a nesting feature now that I am just starting to use. It has come a long way and it is only getting better all the time. The 2D drawing side is limited to a choice few lineweights and some specific architectural symbols but there are some ways around that. One thing I really like is the ability to make changes to the model and all of the subsequent drawings change automatically. Finally the fact that it is an integrated CAD/CAM option makes things easier. Your mileage can and probably will vary ;)
7/12/21       #10: Autodesk Fusion ...
pat gilbert
Bernie
I meant that the geometry can be extracted from Auto Cad 3d
IOW I would think it could be done in Fusion or Inventor, and I have done it in SolidWorks and Autocad 3d
You would then apply the CAM to that geometry from Enroute or whatever
7/13/21       #11: Autodesk Fusion ...
Peter Matos
Just rereading these posts. I noticed that you asked if anyone had done 3D drawings in Fusion360. Perhaps I missed that in my response. If by 3D drawings you mean isometric views, then yes you can do several orientations of isometric views in the drawing section of Fusion360. If by 3D drawings you mean being able to actually show a 3D model in any orientation and then be able to accurately dimension it in the drawing space that is not really possible. There is a workaround tho. I have had to do this a few times when 2D and section views did not tell the whole story. If you take your 3D model space and set the viewspace to wireframe and the background to photobooth it appears like a 2D drawing space. Then you can use 3D sketches and dimensions/driven dimensions to show what you need. Then just orient as needed and take a screenshot of it. This can then be inserted into your title block in the drawings section. This allows almost unlimited drawing views inside fusion360. We often insert images of screenshots from the model space or rendering space in our drawings submittals in the drawing space. If I misunderstood your question then disregard this. If not hope this has helped.
    • Palmetto Cabinet Doors
