Subject: Re: CNC Error
CNC Error
4/18/22
Tim Member
Hi there,
We have a Biesse Rover A 3.40 FT and have an error message coming up.
Error message- PLC9046 ( Slot tool- present sensor lacking (1 in 52).
We have started the machine as usual and carried out calibration then loaded a program but the machine fails to pick up the tool.
Many Thanks for any help
Tim
4/21/22       #2: CNC Error ...
Mark Tomlin
The machine is failing to see the tool present in the spindle sensor. If an HSK holder could be as simple as thoroughly cleaning the cones inside and out. Or it could be the tool locked and present sensor is out of adjustment or failing.
You can iniate the PLC debug and manually load and unload the tool to see if the input is reading the sensor.
Mark
4/23/22       #3: CNC Error ...
Jim Anderson
I work for another OEM Manufacturer and we have a sensor to see if there is a tool in the tool changer position prior to the tool change. if it is misaligned or not functioning, it will not pick up the tool. I suspect this is what you have going on.
5/26/22       #4: CNC Error ...
Erick Member
It's possible to restart matchining without restoring the machine
    • Better Vacuum Cups, Inc.
    • Palmetto Cabinet Doors
