Subject: Re: Alphacam and Output To Laser Projector
3/15/23
Mark
Is anyone using the Alphacam macro "Output To Laser Projector"?
I am looking for feedback on whether this works at all and how anyone may be using it.
I am projecting to an SL laser. The layering control works and it shows a pattern on the router table but the stop button does not seem to work correctly and the communication with the laser is intermittent. I'd love for this to work, it looks like it would perform the functions I need but I don't want to waste time on something that may broken and out of support.
3/15/23       #2: Alphacam and Output To Laser Projec ...
BH Davis  Member
I don't know if this will be of any help but when I ran our SL-Laser with Enroute software I just treated the laser as though it was another router bit. Bit diameter was set to .001 and cutting length to a non-pertinent 3/4".
The toolpatch was created with those parameters and the output included spindle RPM commands and feed rate commands that were ignored by the SL Laser.
Doing it that way we just ran the SL Laser file as we would any cutting file. I altered the WinCNC control software to display the SL Laser .cnc file along with our cut files. We run the SL Laser file to locate our hold down vac pods and position the curved moulding blank. Then the cut file was selected to cut out the moulding blank.
As to the intermittent operation the first thing I would check are the LAN connections at the CNC and at the SL Laser. It doesn't happen often but the terminals can develop corrosion.
3/16/23       #3: Alphacam and Output To Laser Projec ...
Mark
BH,
Thanks - it does help. Any context I can get is valuable.
Do you output a DXF or similar file from Enroute and pick it up with the laser 's software, or did the laser project directly from within Enroute?
The portion of the Alphacam Macro I am trying to use now projects geometry (filtered by layer) directly from Alphacam, while Alphacam is open - attractive from a "program on the fly" point of view, if I can get it to actually work.
It's pretty straightforward to use the SL software stand alone to pick up a DXF.
Mark
    • Palmetto Cabinet Doors
