Particle board cuts good enough to edge band?
9/15/14
Knick  Member
Website: cmsdisplays.com
We have been having trouble with particle board after coming off the CNC. The center of the core seems to be flaky. If you run your fingers over the edge you can get pieces to fall out, almost like there is not enough glue. It seems to be worse the closer to the center. I am involved in trying to figure out if this is normal or if its just us.This causes problems when edge banding unless we drag a sanding block across the edge and blow it off with compressed air before hand. So do any of you have this problem ?
9/16/14       #3: Particle board cuts good enough to ...
craig
There have been previous posts regarding this issue. Try a different panel manufacturer, the quality of the core varies a great deal. I have found that price doesn't always indicate quality core.
9/16/14       #4: Particle board cuts good enough to ...
Knick  Member
Craig
Thanks for the input, we had wondered about that. I will do a little more searching
see what I can find.
Thank you
9/16/14       #5: Particle board cuts good enough to ...
Mac Donald
One trick I've found that works well in a pinch is to run the panels through the bander with the trimmers and cutters backed out so that the panels just get a glued edge. After you seal all of the edges re-set the machine back to normal and run the panels again. Not an ideal solution obviously, but it will help you with the panels you already cut with core blow out.
9/16/14       #6: Particle board cuts good enough to ...
Knick  Member
Mac
That's my problem all the loose stuff is ending up in the glue. They want me to try and rig up something to blow and brush before entering the bander and before I do that I want to make sure the stuff coming off the CNC is as good as we can get it.
Thanks for your input
9/16/14       #7: Particle board cuts good enough to ...
jason
Try reversing the direction of cut on a sheet to see the results of that. My default is to climb cut and I have great results almost all the time but I just did a job with some plywood that I couldn't get a finish like I wanted and I looked at the off fall side of the cut and it was nice, so I changed to a conventional cut on that material and the parts came out nice.
Try that, it may get you where you need to be on the PB. If not, try other suppliers.
9/16/14       #8: Particle board cuts good enough to ...
Wyatt
Does your edge bander have a pre-mill cutter on it - this will provide a trim cut along the edge
Also what brand edge bander are you running ?
The Holz-Her has a pressure cylinder at glue station which penetrates the core of the substrate which we have found helps secure the edge banding
9/22/14       #9: Particle board cuts good enough to ...
Knick  Member
Jason, we do keep a eye on this and there is a slight difference but its worse not better.
9/22/14       #10: Particle board cuts good enough to ...
Knick  Member
Wyatt
We do not have a premill (would be nice)
The Edgebander is a Biesse so it has a glue roller as stated.
