Unwanted J Cut
9/23/14
Frank D. Jimenez  Member
Website: http://www.cabinetpro.com
We are working with a Holzher router and writing code for HOPS. On our dado cuts we are getting a small obnoxious J cut at the beginning of the cut, and then the dado looks fine. For example, if we are making a dado to go from (X1, Y1) to (X2, Y2), the code looks fine. But the cut looks like the picture below. Anyone have any ideas? Your help would be greatly appreciated.
View higher quality, full size image (875 X 654)
9/23/14       #2: Unwanted J Cut ...
Could that be a ramping cut that is not set up properly? If so, where would it be defined in HOPS?
9/23/14       #3: Unwanted J Cut ...
I 2nd the idea of a bad setup on the ramping code. We don't use a HolzHer so can't help there.
9/23/14       #4: Unwanted J Cut ...
Dean Brower  Member
Website: ozfurniture.com
That is what is called a arc lead in and lead out. It could also be a ramping lead in and out. You will have to look in the set up and look for your lead ins section
9/23/14       #5: Unwanted J Cut ...
Dean Brower  Member
Could you post the section of the Gcode you are referencing.
9/23/14       #6: Unwanted J Cut ...
Hi Dean,
Here is the HOPS code that is cutting a dado:
VARS
DX:=2438.4
DY:=1219.2
DZ:=19.05
START
FINISHEDPART (DX,DY,DZ,0,0,0,0,0,'BIRCH PLY',0,0,0)
CALL HH_PARK (VAL PARK:=1,X:=0,Y:=0)
ToolM (3,_VE,_V,_VA,_SD,_ANF,'0')
SP (2228.85,234.96245,9.525,0,2,_ANF,0,0,0,0,1,0,0,0,0,0,0,0,0,0,0,0,0)
G01 (2228.85,234.96245,-9.525,0,0,0)
G01 (1898.65,234.96245,-9.525,0,0,0)
G01 (1898.65,234.93755,-9.525,0,0,0)
G01 (2228.85,234.93755,-9.525,0,0,0)
EP (0,_ANF,0)
Should one of those zeros in the Start Point line be something to straighten out the ramp cut? It seems as though it might be using the x-axis rather than the y-axis (or vice versa). Thank you for looking at this.
9/23/14       #7: Unwanted J Cut ...
I think I found the solution: the 5th variable, 2, means "radial lead in mode" (according to the HOPS manual). I changed it to "1" (which means "lineal lead in mode:) so that the SP command now looks like this:
SP (2228.85,234.96245,9.525,0,1,_ANF,0,0,0,0,1,0,0,0,0,0,0,0,0,0,0,0,0)
We're testing it in a few minutes. Hopefully this works. I'll let you know.
