project 330t axis off
12/5/14
Rob Member
Hi people, my masterwood project 330t is cutting off by 2-3mm. Does anyone know if i can recalibrate it myself and how?
12/9/14       #2: project 330t axis off ...
Neno  Member
Website: http://www.drafting-service.com
Is your tooling correct? ...if so check your stops first.
12/9/14       #3: project 330t axis off ...
Johann Huck  Member
Website: http://www.themachinewarehouse.com
Rob,
It is possible to recalibrate your stops. This is not hard to do, but you do have to be careful when performing this job.
Is your machine cutting off in both X and Y directions or only one of the axis?
Johann Huck
The Machine Warehouse, LLC.
704-839-6615
johann@themachinewarehouse.com
1/5/15       #4: project 330t axis off ...
Rob Member
Its the Z axis. I manufacture doors and it is cutting the lock channel and the hinges 2.5mm too low.
The workpiece dimensions are correct, there is approx 1mm variation in the height/thickness of the vacuum blocks over the bed of the machine.
To be honest, the machine operator before me left, and I am self taught over the past 6 months.
