2 Piece mdf doors
12/18/14
Chris
I am in the market for a program that does a two piece mdf shaker door.
It seems only a couple of company's exist. I would like to know all my options before making a decision.
What are you using and how to do like it?
I would appreciate some insight.
Thanks.
12/20/14       #2: 2 Piece mdf doors ...
John Meachen Member
Do you have a model of the doors?Are you seeking a program that allows parametric adjustment of a standard component ?Are you looking for a program to load on your CNC that will cut a set of components to your specification?
I don't entirely understand your requirements and that is why I am posting questions.
12/22/14       #3: 2 Piece mdf doors ...
Chris
Hi John,
what I'm looking to produce is something like this: (Skip to about 5:20.)
https://www.youtube.com/watch?v=dmEbKOq1mgc
where the frame is one piece, with the panel being the 2nd piece that is inserted into it.
Yes fully parametric. I just want to be able to tell the program the hight and width of the door and have it generate something a cnc with understand.
Thanks.
12/22/14       #4: 2 Piece mdf doors ...
yaakov
what machine do you use?
biesse very easy to create
in homah its alitle problem with the nesting
we sell chines cnc now that controle by
TPA so also very easy
12/23/14       #5: 2 Piece mdf doors ...
Kerry Fullington
Chris,
We use Panelmetrix which is the software in your video. It works great.
2/3/15       #6: 2 Piece mdf doors ...
Ned Lindstrom
Website: http://Witlockeng.com
Yes we make software that does what you want. You can also make the insert panel with profiled edges. You can use different materials and send code to multiple machines.
7/31/18       #7: 2 Piece mdf doors ...
Steve Member
How do the panels get fastened/clamped?
