Biessenest
8/26/15
Danny Member
Does anyone know what the password is to "Unprotect" the worksheets in BiesseNest. I want to add a few things and modify a few things to help with what I'm doing. It's not "Serbs" That only allows me to modify a few titles.
Danny
8/26/15       #2: Biessenest ...
Dylan
Danny not sure what you are trying to do..are you wanting to rename the material sheets?
Contact me directly and I might be able to help...as always,
service@biesseamerica.com is available as well.
Regards
Dylan
www.machineconsult.com
8/29/15       #3: Biessenest ...
yaakov
if you in biesse nest ,i have problem
maybe you can help me other wise need to create script to take care
its about the 2 things:
first if i use 2 tools for nest first its 12mm
then second its 5mm for the onion skin
it always take the 12mm as nesting in the last cut not the 5mm
second-how can i keep the tool order but without change tool any part and nest at last with the nesting tool
thanks
yaakov
9/4/15       #4: Biessenest ...
Jason Scott
Yaakov can you explain that again??
9/4/15       #5: Biessenest ...
yaakov
ok i try from the second point
i make door that have some machining with some tools
but its very important the order of the tools
when i create the nesting in biesse ,i have the option to keep the order BUT
its make part by part
than mean ,if i have 8 tools in one door
and in the all sheet i have 10 doors
(that numbers noraml numbers)
then it change 80 times tool in one sheet
and worth of that ,its cut each part when it finished
9/4/15       #6: Biessenest ...
Jason Scott
I will have to double check but I think when you write your program you need to uncheck the setting that allows the operation to be optimized. It will turn that operation red in your program.
I think that will work. I will run a test when I get a moment and get back to you.
Sorry to hijack your thread Danny.
9/5/15       #7: Biessenest ...
Danny
No problem Jason.
I do MDF doors all day. Most time it's in lots of 5 to 8 at a time. Most doors have 3 to 5 tool changes. I can't say which setting it is but mine only does 1 tool change once per cycle. That is, if I'm doing 8 doors in 1 cycle, it will do all 8 doors with the same tool and then move on to the next tool and then do all 8 doors again.
Sounds like an optimizer setting. Have you tried al 4 Settings ??
Danny
Danny
