AlphaCam Profiling
9/22/15
Troy W Member
Question to AlphaCam programming professionals: I have done an extensive amount of "profiling" using our MultiCam router and AlphaCam software. I am trying to make a "rosette", and keep getting an error when I try to set my "profile" tool paths. I have tried both the pocketing and the Rough/Finish option and get the same error box. The message that comes up is "Cannot find the offset path". I have made sure my "tool directions" are correct. I am using an 1/8" tool for roughing out the extra and then using a 1/16" bit for finishing. I also tried different diameter circles geometries. I don't know what else to try. Any feedback would be appreciated.
Thanks,
Troy
9/22/15       #2: AlphaCam Profiling ...
Snaglpuss
Does Alphacam require that the circles be broken into two pieces.
If I don't break my circles my post screws up the cutter comp.
9/22/15       #3: AlphaCam Profiling ...
Troy W Member
I didn't think of that. I will try that and let you know. Thanks for the input.
Troy
9/22/15       #4: AlphaCam Profiling ...
Troy W Member
No luck on that. I broke the circles and I also put a .002" break in the circle, but that didn't work either.
Thanks again for the response.
Troy
9/23/15       #5: AlphaCam Profiling ...
Seems like that sounds familiar with machining rosettes. I think in the past, I have created surfaces, or made solids to machine. If you can post it, or click on my name to email, I could take a look. May have to do with what another poster touched on. One thing you could try that has worked for me is not to profile the entire geometry. Find a place to break it, and make two tool paths. I know that has worked for me in the past.
9/23/15       #6: AlphaCam Profiling ...
Brian T
Have you tried changing the path to left or right if you are you running on center. Also it may think the tool is to large for the diameters so you may need to shrink the tool size in the code.
9/25/15       #7: AlphaCam Profiling ...
Troy,
So, what was the fix or problem that caused the error? I assume you finished the rosette.
