Collet nut torque settings?
12/31/15
Matt
I've always been a touch concerned with how tight (or, really, how loose) we are tightening the collet nut on our router's collet chucks. Ours uses er32 collets.
Right now we simply tighten them down with the special wrench to "pretty damn tight", but obviously that will vary between the three or four people we have that are authorized to make bit changes.
I am going to contact our router manufacturer, but if anyone is running er32 collets and has some objective torque settings for tightening the nuts, I would be greatly thankful.
It's a very rare thing for us to have a tool come loose, maybe a time or two in the past 5 or 6 years, and those events were fairly benign.....but the thought of tossing a flycutter or miterfold bit bothers me enough to ask.
12/31/15       #2: Collet nut torque settings? ...
Gavin S Member
Website: soraghanwoodworking.net
Matt,
When you say your using a special wrench do you mean a torque wrench? You really should be if your not.
ER32 should be tightened to 120-125 ft lbs of torque
12/31/15       #3: Collet nut torque settings? ...
Zak
Here are some torque settings for various collets.
View higher quality, full size image (555 X 416)
1/1/16       #4: Collet nut torque settings? ...
B.H. Davis  Member
Website: http://www.curvedmouldings.com
Pick up a collet torque wrench. It's available from the typical CNC tooling distributors. They're expensive but well worth having. Takes all the guess work out of tightening collet nuts.
1/1/16       #5: Collet nut torque settings? ...
125 foot pounds is more than you think, especially when using a short handle.
1/4/16       #6: Collet nut torque settings? ...
Dylan
know its promotion, below is link to find part # and relative adapter keys that most use in our industry
Link
1/5/16       #7: Collet nut torque settings? ...
Chuck Hicks  Member
We highly recommend a torque wrench. The max torque on a ER32 is 125 ft lbs. We recommend 80 to 90% of max value. The main thing is to hide the cheater extension bar. They allow for way too much torque and that fatigues the collet and shortens the life.
1/5/16       #8: Collet nut torque settings? ...
Matt
Thanks guys, this is exactly what I was looking for. We will put this to use.
Matt
