Need Help boring Phonelic (WA Compact)
1/20/16
Gary B.
Hey guys I could use some help.
took a project with 10,000 holes in 3/8" Wilsonart Compact laminate. Basically this stuff is a wilsonart laminate on the outside, but 3/8" thick with a phonelic core. I was able to cut it fine with the right bit (3 flute slow helix upcut), but I'm having a hell of a time getting the boring worked out.
I've tried 7500rpm and a 3 meter per minute feed. I've tried with a through bore v point bit (snapped bit on 2nd hole), and a brad point bit (took outside spurs clean off the bit on second hole).
I'm doing this on a weeke vantech nested router.
The holes are 7mm, with a counter sink to sink a 1/4" flat head machine screw.
Thanks for any insight.
1/20/16       #2: Need Help boring Phonelic (WA Compa ...
Your best bet is to route the holes. Last time I machined that type of material, I used a 3/8" diameter diamond bit for the perimeter cuts and a solid carbide single O-flute bit for my 7 and 8mm holes. For the routed holes I used a helical path to cut all the way thru the material. Bit life was surprisingly good. Since you have to do a countersink, maybe you could follow up with a insert v-groove bit with the proper angle. Just bore on the previously routed holes and the tool should last long.
1/20/16       #3: Need Help boring Phonelic (WA Compa ...
Richard
Hi Gary,
I would second that idea of routing not drilling. Specifically I usually use a ramped lead in which forces the tool to spiral down to the final depth.
Would also suggest O-Flute tooling
Couldn't recommend specific feeds at this point as I only use this material intermittently.
Good luck!
1/20/16       #4: Need Help boring Phonelic (WA Compa ...
Gary B.
Thanks guys.....I was out on the shop floor trying to figure this out. As it turns out, the problem wasn't with boring....It was the countersink I had attached to the 7mm V bit. The chips would clog under it and not let the V bit do it's job.
The V bit seems to be running good at 7500 RPM, 3mpm feed and a slow fast slow through mode in woodwop. I'll have to do the countersink as a secondary operation.
5/9/17       #5: Need Help boring Phonelic (WA Compa ...
Jarvis Member
I arrived here looking for information on working with Wilsonart Compact laminate. I am attaching a link to Wilsonarts fabrication manual in case anyone else comes here looking for info.
Wilsonart compact fabrication manual
