woodwop
2/25/16
anthony
need help trying to make a flat fluted column mdf 1" thick with 5 flutes on face.
I program a start point and end point for each flute all have same x start and end. All the y axis are different. when I progam start and stop It only accepts 1-0/1-1 it will not accept 1-0/5/1as a start and stop.it will only make1 flute any advice thanks
2/25/16       #2: woodwop ...
Gary B.
Anthony,
You need to create the 5 lines (contours), then apply each tool to one of the 5 lines. It seems by your post that perhaps you are trying to connect the lines together? don't. apply the first tool to route 1:0-1:1, the next tool to 2:0-2:1, etc.
Good luck!
2/25/16       #3: woodwop ...
Anthony
Gary Thanks for the input I tried that today and still no luck,
3/1/16       #4: woodwop ...
Gary B.
Anthony,
Post the file and I'll take a look.
