Corner trouble on mdf door
2/28/16
Farmer Billy
I know it a setting that make corner the wrong. New to biesse world I'm guessing it on the lead in. Didn't have trouble until we change machine. Any help would be appreciated as alway. Also anybody where to find information on lead in or ramping in the biessebiesse manuals. Thank. Agin.
2/29/16       #2: Corner trouble on mdf door ...
Phill
Website: http://dreamclosets.org
FB,
Just a guess but it looks like you're starting your rout in the corner. Try starting your rout in the middle of one of the sides and it should eliminate that issue.
2/29/16       #3: Corner trouble on mdf door ...
Place your start point midway on one of the long edges, ramp in with the z + linear axis to proper depth, and if possible, overlap the start point equal to or greater than the tool radius and you will have a nice clean cut without a tool mark.
2/29/16       #4: Corner trouble on mdf door ...
Farmer Billy
Really hate to ask this like i said i new to biesseworlds old software i used couldnt start in middle so if u can tell me how to start in the middle i cant move start point (well if i can i havnt figure it out) how u do?
thank
2/29/16       #5: Corner trouble on mdf door ...
dustmaker1 Member
I can not say for sure with Biesseworks because all my experience is directly with Biesse controllers. If you program directly on the controller you can start processing anywhere you want.
If I was creating cad and code in Vcarve you just would go into node editing, add a node in middle of vector and make it start point. Can not say in Acad have not used that program for 20 years, I would think though it would just be to get Biesseworks to start at node in middle of vector.
All my experience is with other cad programs and directly with Biesse controllers so you may already know more about your programs than I do.
Paul R
2/29/16       #6: Corner trouble on mdf door ...
Dylan Bayliss
black arrow is the lead in set distance (positive or negative values)
red arrow is the overlap gap between the in and out..
apply these values after profile is created or could crash..ie mill info..generate geometry then go back and manipulate the lead values.
as always service@biesseamerica.com if any additional problems.
regards
dylan
2/29/16       #7: Corner trouble on mdf door ...
Farmer Billy
tHANK TO ALL U I REALLY APPRECAITE THE TIME U TOOK HELPING ME.
6/5/16       #8: Corner trouble on mdf door ...
Jason Scott
It's a little late I know but you an also either use the rectangle function to draw that or you can start drawing your lines I. The middle of the line.
