Cutting Plastic Laminate
5/12/16
Nick Cook Member
Website: http://www.cedarrivercabinetry.com
I'd like to try gluing up laminate on particle board and then cutting the pieces on my Weeke CNC machine. Any advice on cutters speed etc?
5/12/16       #2: Cutting Plastic Laminate ...
David Egnoski  Member
Website: http://www.richmondcabinet.com
I've used the 3184XP with pretty good results. Run at 16k rpm and 500 ipm.
The laminate will degrade the cutting edge but I think I got about 100 sheets per tool. Maybe slightly less.
5/12/16       #3: Cutting Plastic Laminate ...
Sam Jackson
I second David's post. We use the exact same setup. Good to know we are doing something right!
5/16/16       #4: Cutting Plastic Laminate ...
Jason Scott
I haven't used one but my buddy does a lot of that and he uses a diamond because some of the laminates eat tooling so fast.
5/17/16       #5: Cutting Plastic Laminate ...
Anthony Member
Hello
i am still a beginner in the cnc world and i work i own a carpentry
if i may ask you how do you know which bit to use ? and what feed and speed to set it to ?
hope you can help me with that
thank you in advance
5/17/16       #7: Cutting Plastic Laminate ...
Jason Scott
Your tooling manufacter should have some recommendations. The idea is to take enough material to keep the bit from overheating.
Vortex has a smartphone app I use all the time.
