CNC bit Chipping
7/12/16
Bob
I have some trouble with 5/16 bit.
Somehow this bit is making cut which is chipped and clean when making dado cuts . That clean cut looks like it is for male dado, chipped cut looks like for female dado.
I am sending picture when it shows that some dados have clean cut and the rest of them is terrible chipping . It is the same bit.
Any idea what is happening ?
7/13/16       #2: CNC bit Chipping ...
If you have been reading posts here before, you should know that you need to provide more information. What kind of bit? Up spiral, down spiral, or straight. How many flutes? Feed and speed data. Did you ramp in the cut, or plunge vertically? Single pass? Just guessing, without any important information, it looks like a plunge cut, single pass where the two cleanest cuts were first and second in order. Rpm's too high, feed too slow so the bit got hot and chipped out the remaining cuts. That is only a guess. Another possibility is poor quality core on the board is contributing to the problem.
7/13/16       #3: CNC bit Chipping ...
Jerry Member
Are both cuts going in the same direction. One looks like it is packing the chips in front of the cut and the other looks like the chips are behind
7/13/16       #4: CNC bit Chipping ...
Brad
As asked previously...
1. What type of bit? Up Shear, Down Shear, Compression, Straight?
2. Are the depths of the dadoes all the same?
7/13/16       #5: CNC bit Chipping ...
Brad
...if using a Compress bit and the depth are NOT the same then -
The shallower cut would be exposing the Up Shear section of the tool to the top melamine surfece, whereas the deeper dado would bury the Up Shear section and the Down Shear part of the cutting edge would leave you with a clean, non-chipping finish.
(Could not tell conclusively from the image, but depth could be different.)
BTW: What is the difference between a Male and Female Dado?
7/13/16       #6: CNC bit Chipping ...
Bob
This is 2 flute 5/16 down cut . dept should be the same .
Attached is picture of final product . Cut for male dado cut is clean and for female dado do chipping . Any idea ?
2Full_page_photo.pdf
7/13/16       #8: CNC bit Chipping ...
Richard
Hi Bob,
I agree with Jerry it looks like for some reason the female grooves are being routed in a different direction to the males. Either that or in 2 passes. Watch carefully when it's cutting and see if it's making 2 passes & which direction it's cutting.
Good luck.
Richard
7/14/16       #9: CNC bit Chipping ...
Chuck Hicks Member
Bob,
What are the feeds and speeds you are running with this tool?
7/14/16       #10: CNC bit Chipping ...
Bob
Attached is picture of tool setup
View higher quality, full size image (496 X 573)
7/14/16       #11: CNC bit Chipping ...
Chuck Hicks Member
What percentage of the feed rate are you running?
7/14/16       #12: CNC bit Chipping ...
Bob
100% and i can set that just in material property
7/14/16       #13: CNC bit Chipping ...
Bob
here is screen shot of property
View higher quality, full size image (992 X 291)
7/15/16       #14: CNC bit Chipping ...
Jason Scott
your lowering speed seems really high. Could your bit have been damaged and just cut the dadoes after the tenons?
7/15/16       #15: CNC bit Chipping ...
Blaine
It appears that your part is not securely held.
By that I suspect the part is vibrating up and down. There is usually an unusual noise (pitch) change when the part is being cut, if this is happening.
Also, poor dust extraction can exacerbate this as well.
Blaine
7/15/16       #16: CNC bit Chipping ...
Bob
Hi Blaine
No there is not any vibrations . If you check picture you will see that is on same sheet clean cuts and chipped . CNC 5/16 bit make clean cut for tenons ( blind dado ) and chip so much on mortise ( blind dado )
7/15/16       #17: CNC bit Chipping ...
Blaine
Hi Bob.
Something else to look into, I noticed the cuts that are chipping are not parallel to X and Y, they are somewhat diagonal.
Try cutting parallel to X and Y, then try the diagonal cuts again. You may have some oscillation when the machine is interpolating the XY linear moves that is causing the chipping.
Blaine
7/15/16       #18: CNC bit Chipping ...
Bob
i check that ready .
7/18/16       #19: CNC bit Chipping ...
Blaine
Put in a new tool, and try this.
Try cutting a hexagon approximately 10" in diameter, clockwise.
On the same sheet in the same program, offset the the geometry 5" or so to allow good visibility of the cuts, use the same geometry in the opposite direction, counterclockwise.
Is there any difference in the amount of chipping, and where it occurs in the 2 hexagons?
Please post a picture.
Thanks,
Blaine
7/22/16       #20: CNC bit Chipping ...
Gary B.
post a picture of the bit....
7/23/16       #21: CNC bit Chipping ...
Jarvis
We just seen the same thing
I grabbed an old scrap pc of melamine and cut that and it dont do it so we determined that we got a bad unit of material
