Rover B.35
9/13/16
Johan Member
We do a lot of vertical drilling on our Rover B.35
For some or other reason we cannot get the machine to drill with more than one drill vertically. We have even made new drilling program. Can it be offsets
please help
9/14/16       #4: Rover B.35 ...
Dan
Are you using BW?
It should be automatic if the tool symmetry is set up properly.
There's some program notes on page 462 of the manual as well.
If you are importing from cad with a PP - symmetry needs to be enabled.
9/15/16       #5: Rover B.35 ...
Dylan Bayliss
Website: cnc-tool.com
Johan, probably your optimizing in general settings is not enabled or as stated you do not have symmetry setup as a grouping. can send over a doc. that helps with that, just let me know. As always, service@biesseamerica.com is avail as well
Regards
Dylan Bayliss
www.machineconsult.com
