Error in Masterwood Winner 3.2
10/2/16
ObaydaF Member
Hello,
I am using a Masterwood Winner 3.2 Machine,
It starts working, then it stops giving an error 02.01.1095 which is an emergency switch error. I try to rerun it, so it doest run, giving a Z Fault. Everytime I need to turn off it, so it resets. Can anybody help please?
10/2/16       #3: Error in Masterwood Winner 3.2 ...
cabinetmaker
1- check your air pressure
2-look for sensors that are loose, that may not be engaging, to tell the plc parts are in the right place
3- check all the e stops on the entire machine and reset them all
4- check for small pieces of materials from processing that may be blocking movements
good luck
10/15/16       #4: Error in Masterwood Winner 3.2 ...
ObaydaF Member
Thank You very much dear
2/13/19       #5: Error in Masterwood Winner 3.2 ...
john@c-hcabinetsandcountertopsinc.com Member
I have both a Project 317 and a Project 450 and both do it. They kick out in the x axis motion for no reason. the 317 will reset immediately while the 450 sometimes takes hours before it will let me reset. Even when shutting completely down and rebooting everything. I have contacted support and sent them the message about it and the information they want and have never gotten a response from them for the two plus years I have had the 450. I have had technicians look at it and no answer??? It has to be something in the carriage assembly because both machines do it and only in the x axis motion. the same error that an emergency stop has been depressed when none have. Had it happen when Rob Parton was here an he could not find out why it does it or what is causing it.
