CMT solid carbide drill bit sharpening
10/26/16
We use 8mm solid carbide CMT HWM 14-6346 drill bits in our boring machine. Our normal sharpener Vortex says they can not sharpen them because of the geometry.
Can anyone recommend someone who can? They are $50+ each.
10/27/16       #2: CMT solid carbide drill bit sharpen ...
Jerry Member
what angle are they? I have a drill Doctor that has a diamond wheel that will sharpen carbide bits
10/27/16       #3: CMT solid carbide drill bit sharpen ...
Chuck Hicks Member
On those, you just sharpen the end of the drill back to what you need.
10/27/16       #4: CMT solid carbide drill bit sharpen ...
Jerry that will not work in this case.
Chuck I am not sure I understand what you mean.
View larger image
10/27/16       #5: CMT solid carbide drill bit sharpen ...
Chuck Hicks Member
Bill,
You sharpen them down or make the overall length of the bit shorter.
10/27/16       #6: CMT solid carbide drill bit sharpen ...
Who sharpens it? I understand it gets shorter when it is sharpened but I do not have the equipment to sharpen it.
Is there a company who can?
10/27/16       #7: CMT solid carbide drill bit sharpen ...
Chuck Hicks Member
We can, give us a call to discuss.
877-465-7012
