cnc software
11/5/16
tommy Member
just entering the cnc world,purchased a used komo.need software recomendations please
11/5/16       #2: cnc software ...
Roman
A-Cad & Router-CIM
https://www.youtube.com/watch?v=8Xoj1OXPqj4
om/watch?v=ir2-guxCPXg
https://www.youtube.com/watch?v=DCauRFPHStk
https://
www.youtube.com/watch?v=Aha8ksconik
11/5/16       #3: cnc software ...
To do what?
11/6/16       #4: cnc software ...
tommy
I will be cutting parts and radius templates using melamines or plywood
11/6/16       #6: cnc software ...
Parts for what? Kitchen cabinets, stairs, windows, commercial cabinets?
11/6/16       #7: cnc software ...
Brian
Back in the day KOMO and RouterCIM were a standard pair as I was told RouterCIM was a sister company. As far a making G-code with tons of options and user configuration you cant beat RouterCIM. You need to look at your skill level, what you want to do and where you plan to go. There are a lot of options. All produce code but some produce more efficient code with less editing.
11/7/16       #9: cnc software ...
Tommy,
I use Alphacam Ultimate, but it sounds like you won't be very demanding on your CAM software. You can spend a whole lot of money to get the essential code you need to cut parts and templates, but there are other basic software that will do the job for you. Start your research on the low end. If work evolves to where you need the muscle of a higher end package, then buy it when the need arises. Your money is better spent on tooling and whatever your machine needs right now. The good news is you have a Fanuc control and just about any package can write code for that. Oh, and welcome to the club! Its been getting bigger every year.
11/7/16       #10: cnc software ...
Just curious what will you be cutting templates for? Field work?
Will you be nesting in the future?
11/7/16       #11: cnc software ...
If all you're doing is odd shapes and not a lot of nesting, there are a couple of really budget ways to do this.
I use CorelDraw for odd stuff ($600.00 or so) but I know a guy who uses Inkscape ($ free).
For a CAM software checkout SheetCAM. Less than $200.00 and it can do a lot of things, including reading svg files from Inkscape. I use it to run my 5X10 Biesse Arrow with 2 spindles, a tool changer and a drill block.
So, if you don't mind a little experimenting, you can get this happening for quite a bit less than $1,000.
11/13/16       #12: cnc software ...
Jason Scott
enroute6 is only $89 a month. It will do more than you need.
