weeke venture vaccume
10/13/18
hello all hope your having a great day
i got some carving work to do and i was wondering if any one knows if a weeke can function without vacuum pump running ?
10/13/18 #2: weeke venture vaccume ...
Isn’t there a way to disable the low vacuum warning/fault when surfacing the table?
10/15/18 #3: weeke venture vaccume ...
From what I understand from my machine (Vantech 480), if the filename is "_____spoil.mdb" it won't pay attention to the low vacuum warning. That's 5 underscores before "spoil". I found out the hard way because I changed the spoilboard surfacing program's file name and had to call Stiles support. I don't know if it's just the 5 underscores that's needed, or the entire filename. Never experimented afterward. Can you mount your carving blank onto the table and cover the rest of the spoilboard with something so you don't trigger the warning? You could also gasket off a section of the table that you don't want vacuum going to.
11/19/18 #4: weeke venture vaccume ...
thank you for your help
i own a weeke vantage 38 l i could not find any way to do so , i am waiting for the response the company .
i would like to ask where can i get the spoilboard cleaning using the file with "_____ "
i amhaving big problem when surfacaing my spoilboard
