Cnc not working
3/18/21
Denisha Shelburn Member
We have a SCM pratix s cnc machine and all of the sudden the auction button isn’t lighting up. It’s suctioning down. So I don’t know what is going on. Is there anyone who can help me
3/18/21       #3: Cnc not working ...
rich c
Usually a magnetic contact involved. Do you have a multi meter to diagnose where the current is and where it ain't?
3/18/21       #4: Cnc not working ...
Start with the simplest/cheapest possibility. Check to see if the lamp is burned out.
3/19/21       #5: Cnc not working ...
Chris
It’s not going to light up unless you have enough vacuum pull down.the factory usually sets them up pretty high. You can lower the value. Loss of vacuum can be a flat table gasket,rolled gasket,ultra lite mdf,dirty filters.
4/15/21       #6: Cnc not working ...
Jim Sherrod Herron
On my Weeke there is a vacuum sensor that can become lodged with sawdust.
Take it off, tap and blow it out, or replace it.
You can bypass it in a pinch, but I replaced mine straight away.
Wasn't prohibitively expensive.
    • Template Services
