SCM Pratix S15 issues
11/21/21
Bryan
My custom cabinet shop acquired this router used about 3 months ago. I have more or less been the main operator, this machine being my first experience running a CNC router. We use Cabinet Vision to create jobs and the router is loaded with Xilog Plus as well as SCM pgmtoiso.
The machine has worked great until a few days ago. Attempting to cut out a dxf file the router finished the boring operations, grabbed the outline tool, traveled back and froze. I tried running a few different sheets of case parts and same thing. It freezes with different tools. When I try to measure a tool it will sometimes put it back sometimes it won’t.
Yesterday when I started up the machine the PC was stuck at a DOS screen asking me to input the date and time. This got me thinking to replace the CMOS battery so I did that. Still no luck. Now today the PC no longer turns on with the router. Have had other intermittent problems such as the dust shroud sometimes does not drop down to cover the material while routing.
We are going to try and have a tech come out but it sounds like the guy is slammed. Any ideas or help would be appreciated.
11/21/21       #2: SCM Pratix S15 issues ...
Jeff
Where are you located. Did you get and software that originally came with the machine when you bought it?
11/21/21       #3: SCM Pratix S15 issues ...
Bryan
We’re in Northern California. We bought the router from a local cabinet shop. As far as we know, the previous owner ran the software that came with the machine, and in turn left the computer as is
11/21/21       #4: SCM Pratix S15 issues ...
Jeff
What your explaining seems to me like it shouldn’t be related .
The operating software the scm is using is Kvarna, maybe some perameters were changed somehow? Maybe your Controller is giving up the ghost? Maybe you are having a power issue somewhere, your SCM should convert and run on 24 volt.
You can contact the folks in Georgia at SCM and they will go on to your computer remotely and do some trouble shooting, there is a yearly fee, but they are really good.
I am in Canada and SCM here is terrible.
11/21/21       #5: SCM Pratix S15 issues ...
Bryan
What does that mean that the controller is giving up the ghost? A power issue would make sense. So far I’ve only gotten one PLC alarm when the router froze before making its z movement. It was an alarm 52 which was “the path cannot be followed”. Maybe the issues aren’t related. I was thinking they were since they started around the same time
11/22/21       #6: SCM Pratix S15 issues ...
Jeff
Bryan
The controller is the electronics and software that takes the input from your g-code or program and transmits the signal to the motors that run the axes.
They sometimes go bad, the controller also has a battery that may need to be changed, it is a similar battery to an AA size.
11/22/21       #7: SCM Pratix S15 issues ...
Bryan
Thanks for explaining. I was able to process about 15 sheets this morning without problems. The external Computer is still having issues not turning on with the router. I had to remove the side panel and manually hit the power button. I can check next time I power the router off and on to see if it’s fixed. I’m going to process the rest of the sheets I need cut before I shut it down again.
11/23/21       #8: SCM Pratix S15 issues ...
Pdub Member
The 1st problem may have to do with your post. We had a similar problem with our Pratix back when we go it. Programs with a radius sometimes had issues. It turned out Planit's (then) CV post needed more decimal places in the post to compute curves? Their tech support fixed it.
I feel like there's a setting somewhere for getting the computer to turn on with the machine. Can't remember exactly though. Those machines typically have "phone support" for life. Meaning you can call in and ask questions but they won't Teamviewer in to see what's going on. That could likely be answered without TV. See if the shop that sold it to you will call in?
Protect that handheld with your life. The machine will not operate without it and they are expensive to replace! It's a stupid design that I believe they've gotten rid of. Our first one had the wires ripped out when the chord was twisted too many times. Luckily it was under warranty. The replacement started getting glitchy last year and the SCM tech said the touchscreen was likely going out. My guy painstakingly replaced the touchcreen with the older one we had and it worked. Now we ONLY use a stylus with the touchscreen.
11/24/21       #9: SCM Pratix S15 issues ...
Jeff
I would try what Pdub said and see if the old owner could get support. I think SCM wants about $500 a year for support where a tech will log on to your machine with teamviewer.
There is a setting that has to be turned on to start your computer when you turn your machine on, I will see if I can find it later.
11/24/21       #10: SCM Pratix S15 issues ...
Bryan
Thanks for the advice. I did call into SCM yesterday and they were very quick and helpful. The issue with the computer powering on is fixed. I had to go into the BIOS and enable the “power on after failure” option. Why it became disabled I don’t know. Maybe the CMOS battery died. As far as the router stopping during operation, the tech said it could be an issue with the tool compensation we’re using. We may need to use a different method. I didn’t fully understand what he explained, but it sounded like it could be a following error outside of the threshold which causes it to stop operation
12/30/21       #11: SCM Pratix S15 issues ...
Bryan Gossic
Update: I figured out the problem with the router freezing mid operation today. The hood casing was getting jammed and not raising enough to trigger the sensor although it appeared it was. I noticed the casing looked like it wasn’t fully seated, pushed it up and away it went. It was waiting for the current operation to complete before moving on to the next. Now time to throw some money at repairs! Hopefully this helps someone.
    • Palmetto Cabinet Doors
