Drill for Hinges on CNC / Edgebander
8/25/22
Rich Member
Website: http://www.rosewoodnyc.com
New Startup Shop here with a Biesse 5x12 Rover K and Holzher 1057 XL C Bander .
We are having the new edge bander installed this week and it currently without the nesting shoe .
My initial thought was to have the CNC take care of all the boring and Drilling, but didn't realize that presents a problem for the bander.
Im torn on the decision to have the nesting shoe installed or not. I hear without the shoe, i should have better edge finishes.
I currently do not have any setup for hinge drilling at the moment other than a hinge jig.
What are you guys doing and opinions on it?
8/25/22       #2: Drill for Hinges on CNC / Edgebande ...
Mark
Rich,
Seriously, buy and install the shoe. Likely around a grand? No separate op on the press, or for that matter no press at all, switch at will between Blum, Grass and Salice, etc (but definitely stick with Blum) and switch to the inserta hinge, short money for the better, quicker more versatile job.
I generally pocket the large cups with a router bit, but some have had success with a 35 mm brad point in the drill bank, or so I have heard.
I run a Biesse edgebander with perfect results over the hinge cups, with the appropriate bridging device, slightly different than the HolzHer setup but no matter No edge quality issues at all.
8/26/22       #3: Drill for Hinges on CNC / Edgebande ...
Derrek
Website: http://www .closetdr.com
We had this issue previously. We cut mdf plugs that fit in hinge hole to keep copy wheel running smooth. I believe Fastcap has a product for this as well that is adjustable
8/26/22       #4: Drill for Hinges on CNC / Edgebande ...
Something new everyday.
I have 4 CNC,s 2 of them Biesse, and have no idea what a nesting shoe is.
Anyone?
8/26/22       #5: Drill for Hinges on CNC / Edgebande ...
Derrek
Each trimmer usually has a large copy wheel that rides on the panel and you adjust trimmer to it. When u have an imperfection on panel wheel will raise up or in case of hinge hole drop into hole and trim to much. To solve this they make a long shoe that slides on panel or like on my Vantedge has multiple copy wheels so the trimmer stays flush with panel in the area of hinge hole.
See attached photo of my glue scraper it has 3 rollers only pic I had on phone
8/26/22       #6: Drill for Hinges on CNC / Edgebande ...
Thanks.
8/27/22       #7: Drill for Hinges on CNC / Edgebande ...
I do what Derrek does, I just made a pile of plugs .5mm smaller than the cup size and made them the depth of the cup cut.
I use a 35mm bit in the drill block. 8mm for the pin holes. Seems easier/faster than a pocket operation to me.
8/28/22       #8: Drill for Hinges on CNC / Edgebande ...
Quicktrim
Same as Karl here, holzher triathalon without the nested based kit.
8/29/22       #9: Drill for Hinges on CNC / Edgebande ...
Andy Officer Member
We use a 5mm drill bit to mark pilot holes on cnc, edge band and than the guys used the dimple as a center line on regular blum hinge machine. Found its much faster than trying to screw around with plugs at the edge bander.
8/30/22       #10: Drill for Hinges on CNC / Edgebande ...
I don't think the plugs slow anything down.
They get dropped and roll off sometimes, but that's why you make a ton of them.
I try and do the hinges as not the last edge. Run the hinged edge, then on my way back to the feed, I dump them out on top of the bander. Shove it through again. I'm sure it varies bander to bander, but I almost always get back to the in feed before it's ready to accept the next part.
8/30/22       #11: Drill for Hinges on CNC / Edgebande ...
Pdub Member
We used to use the puck method on our old Holzher. Recently got a new Biesse with the "shoe" and love it. The puck works, but the idea is to make it so that the puck is slightly proud of the panel in case 1 door is slightly less thick than others (material inconsistency) , it won't cut into the door. Now you have a small lip of edgebandng to sand/ scrape off.
If instead, you're going to band and then bore afterward, or if you're boring 5 piece doors, I'd suggest figuring out how to run "ops only" program with your CNC as opposed to a hinge boring machine. I suppose it depends on what software you're using.
We pocket with a 1/2" bit. If you use the drill, occasionally the "veneer" (or laminate or whatever) can break loose and spin with the bit so that it doesn't cut at all. Best case is no hole. Worst case is damaging your CNC.
8/30/22       #12: Drill for Hinges on CNC / Edgebande ...
Regarding drilling the hole, we took the extra time to pocket 0.030 or so under size and use the drill bit just to clean up the hole.
8/30/22       #13: Drill for Hinges on CNC / Edgebande ...
Derrek
Website: http://www.closetsr.com
“We use a 5mm drill bit to mark pilot holes on cnc, edge band and than the guys used the dimple as a center line on regular blum hinge machine. Found its much faster than trying to screw around with plugs at the edge bander.”
I would love to see your time studies on this. I find it very hard to believe that adding an additional step, including the handling and transportation, along with the cycle time of the hing machine is faster than putting a plug in a hole and pushing through a bander?
8/30/22       #14: Drill for Hinges on CNC / Edgebande ...
Andy Officer Member
Derek,
For me personally its faster for a few reasons
We do a ton of shaker and custom doors that don't come off the cnc and therefore we already have a system in place where when you pick a up door and lay it flat to put the hinge cups on it (which you have to do either way even if you have a automatic inserter) you bore it first, put hinge cups on and put the handle on all in motion so we are really not handling it any more than we would to begin with.
Second being majority of the time we have helpers on the edge bander, and the amount of time that they would forgot to put those plugs in and burn through a door is way more expensive than boring it when you put cups and handls on.
Third we do a ton of locks, and its a complete waste of time to switch out our drill block from the lock plug to the 35mm boring plug, yet alone can't do it both at once anyway.
So that's my time study, down the road when we get a new bander will probably bore them out first but at the moment its way more effective to dimple.
8/31/22       #16: Drill for Hinges on CNC / Edgebande ...
Rich Member
Do you guys have a picture of this plug? Does it need to be tight? or Can it be loose?
8/31/22       #17: Drill for Hinges on CNC / Edgebande ...
Derrek
No they don’t have to fit tight 33mm is good
See video of mine 10 years ago
Edgebander plugs
9/2/22       #18: Drill for Hinges on CNC / Edgebande ...
D Conti
I guess I am just old school. I bore and install my hinges on a hinge machine after the door is banded. We don't use inserta hinges just plain old hinges with dowels. I have the software set up to cut a hinge 4" on center from the top and bottom of each door. The hinge plate is cut into the cabinet side accordingly. On large doors with a third hinge it is in the center of the door. Four hinges do become an issue and you have to check the box (hinge plate for location) but we do so few of these that it is not a problem. The only issue we ever have is on ADA sink bases were the hinge is 8" from the top to allow for a 4" skirt board. We have aux stop set there and you must make left and rights. This way if we make 5 piece doors they get bored the same way and if there are MDF doors we do not have to do a flip side to the door. I have been doing this for years without any issues. I think that pressing in a hinge with dowels is about as quick as you are going to get, plus if there is any sort of imperfection in the banding we can always put it on the side that will not be seen. This also eliminates the need for plugs or speciality shoes. This just works for me, and I have been around awhile and am pretty set in my ways. I am sure that the plugs and /or shoe work just fine it is all just another way to skin a cat. I am also not a big fan of inserta hinges and their extra cost.
9/21/22       #20: Drill for Hinges on CNC / Edgebande ...
Rich Member
We have the nesting shoe , but not installed . I can have it installed at part of sales agreement if I wanted it .
We made some 33mm plugs on the cnc and dropped them in . Ran a door through the bander . The dust collector sucked the plug up and we damaged a door from that ran .
We tried another door but this time put blue tape over the plug . Seems to work fine after that .
Is this normal ? Are you guys taping your plugs down ?
9/23/22       #21: Drill for Hinges on CNC / Edgebande ...
I don't tape them. Try making them a little more snug. Not tight enough they friction fit, add don't fall out, but tighter than you've got them? I'm pretty sure I made mine 34˝ mm, but I'd have to measure one to be sure
And I'm jealous your dust collection is good enough to suck them up.
    • Country Saw & Knife
    • Charles G.G. Schmidt Co.
