Commercial Kiln Drying
Proportionate venting
2/16/14
Henco Viljoen  Member
Website: http://www.tskilns.co.za
Hallo Dr Gene.
I am tasked to set up a drying schedule for a kiln that uses proportionate venting. Having a preference for quick open/close venting, because I believe it is more energy efficient, I will be feeling my way through this one.
In my mind, and in practice here in SA I have not seen an installation where proportionate venting have been setup correctly - referring to the drying schedule - , meaning that except for during warm up, conditioning or equalizing, vents would be 100% open, or 100% closed for extended periods of time. This to me means that set points at that stage in drying is not correct - the schedule is either to harsh (100% open) or too soft (100% closed) for the amount of moisture coming off the timber at the time. Also when vents stay 100% open for long periods of time,the main and booster steam valves also stay open for extended periods - wasting boiler energy. 9 out of 10 times, after a sawmill install a fancy new kiln with proportionate venting, 6 months down the line they have buy a new boiler...because operators, and sawmill engineers for that matter, do not understand the effect that badly setup proportionate venting has on steam usage.
My question: is there a rule of thumb I can use, to balance effective proportionate venting, and energy loss? I am thinking that moving to the next phase in drying, proportionate vents could be 100% open for a couple of minutes, but then should close slightly. Maybe when vent reaches ±80% closed, it is time to move to the next phase with a slightly bigger depression, and starting again with 100% open vents...closing slowly until the drying gradient at that set point needs to be made harsher?
2/24/14       #3: Proportionate venting ...
GeneWengert-WoodDoc
Proportional vents are indeed widely used in the U.S. and Canada and Europe. A control system will automatically determine the correct percent opening...it is continually considering the present opening and the trend toward too dry or too damp. The trend is based on a small change from desired, so it appears that conditions are constant. No change in the schedule is required.
Ok?
