Commercial Kiln Drying
Oak kiln Cool Down
4/2/14
Josh Member
I have heard of another kiln operator performing a "cool down" on all his green oak charges at fiber saturation. He turns off the fans, heat, spray, opens vents and man doors for 24 hours. He claims it draws the moisture out of the center of the board and helps dry more evenly. He also claims you can shave a couple days off the end of the schedule by being able to move faster through it. Maybe the is a question for Gene but others please reply I am interested to see if this is common practice. Thanks
5/9/14       #4: Oak kiln Cool Down ...
Gene Wengert-WoodDoc
I have never heard or seen this.
It sounds like that after 24 hours, you might have lumber that has a gradient similar to air drying. During the cool down, moisture will move toward the surface, although at a slower rate than if the wood was hot, meaning slower drying. Also, the humidity during cool down will likely be higher than if the kiln were running, meaning slower drying. Of course, if the RH during cool down is lower than the kiln schedule, that will dry the lumber faster, but usually, the wood is already drying fast enough and we do not want it drying faster. But if the kiln schedule is too conservative, then this lower RH will indeed make it dry faster.
During this cool down, the lumber will dry, as there will be a moisture gradient within the lumber. So, shutting off the kiln will result in some movement of moisture from the core to the surface, just like in normal drying (unless the kiln is too humid).
It is hard to believe that just 24 hours will make any difference. In fact, we have had some kiln operations that shut the boiler down for a weekend...it is called part-time drying. These operations have never reported and I have never seen any improved drying when the heat is turned back on Monday morning. So, I believe that either this report you have is bogus or there is another problem that the cool down is helping.
Finally, lumber is never at the fsp. When the average CM is 30% MC, the core is wetter and the shell is drier. That is, there is a small zone at the fsp, and this zone develops within a day after the kiln is started and moves deeper into the lumber for quite some time, maybe disappearing when the average MC reaches 20% MC.
