Dust Collection
Subject: Re: Combustible Dust - do you consider it a collection system issue? ... vo
8/29/13
I'm surprised @ the # of shops with plastic duct. The specs not allowing mechanically fed sanders and molders means no wide belts, drum sanders etc! A shaper is often referred to as a spindle molder and very often has a power feed, making it mechanically fed and therefore can not use an open type collector. True??
A few years ago we investigated a spark detection system. We would have had to totally revamp our duct work and the cost seemed really high for what they amount to. We operate two collector, one for the panel processing area and one for the solid wood area. 20hp & 15hp both are outside. We are in a state that has freezing temperatures so the nozzles have to be located within the building for the spark system. Distance from detector to nozzle becomes an issue for our system.
In this jurisdiction duck work must be installed by a licensed heating & a/c company. At one point I asked one of those companies about installing some duct work. Their response was that the design had to be done by a licensed engineering firm. You can see where this is headed. My guess is, there's not one shop in this entire state that meets the local code requirements.
11/19/13       #2: Combustible Dust - do you consider ...
Jeff Schlentz
Website: http://dustcollectorservices.com
A licensed HVAC company has a different license than a specialty contractor for dust collection systems.
We have a C61 & D34 license allowing us design, installation, etc of dust collection systems. We design the ducting, size the collectors, complete turnkey installation, service, etc.
Stay away from an HVAC company, its a completely different animal than dust collection systems.
11/19/13       #3: Combustible Dust - do you consider ...
Yes, I know that about HVAC companies but that's what the local code calls for.
11/19/13       #4: Combustible Dust - do you consider ...
Jeff Schlentz
That seems redundant and you are paying for services twice. If you had a competent company that was licensed in dust collection the jurisdiction should allow that.
Where are you located? I am sure that I could find someone knowledgeable & licensed that could assist you.
11/19/13       #5: Combustible Dust - do you consider ...
Don't need any help. Running fine. Lincoln, NE
I had help on one of my long past shops from Murphy Rogers, really stupid design! Trunk line increasing at every branch for a three man shop. @ most 2 gates open at once. Result of course was massive drop out in the largest section of the duct. Know a lot more about it now. If I ever get $ ahead I'd like to move the cyclone and redo all the duct work in the solid wood processing area. Won't happen soon. Lots of other projects. Getting our IMA pod & rail machine running is current, expensive, project. Always something.
