Dust Collection
Subject: Re: Respirator for neck breather
3/10/16
David Eakins  Member
Website: http://www.finewoodworks.ca
I operate a custom woodworking business. I recently underwent a larygectomy and now breath through a stoma (port hole) in my neck. Therefore a normal style respirator or dust mask does not work. The closest thing I have been able to find to use is a surgical type mask rated N95 that ties around the neck. Unfortunately, it does not seal adequately around the stoma. As the stoma leads to a direct line to my lungs, protection against saw dust is paramount.
I no longer use any solvent based or harsh chemical finishes, so I am not too concerned about protection against them. Has anyone had to deal with this that may have a solution.
3/26/16       #2: Respirator for neck breather ...
Kevin Jenness
You might look into a powered air purifying respirator with an extended hood. These have positive pressure within the hood so a seal is not so important.
