Dust Collection
Water in Air Compressor lines
3/19/13
Scott Weinmann
I have an abundance of water in my air compressor lines. I am a general contractor who does an occasional job or two in my shop and do not want to spend a lot of money on my air delivery system, but I need to eliminate most of the water.
I have done a little research online and found an idea to use 3/4" copper and build a radiator of sorts using 5-10' lengths of pipe connected to upper and lower laterals with the air coming in on the bottom of one side and out the top of the other, the theory being that the water will condensate in the pipes and be able to be drained out the bottom of the contraption... sounds plausible and affordable.
Does anyone have any experience with this, or know of another low cost solution?
3/20/13       #2: Water in Air Compressor lines ...
Dave Edgerton  Member
Try to drain your compressor system daily and let water drain out. Also have pipes to the station slope back to the compressor.
3/20/13       #3: Water in Air Compressor lines ...
Leo G  Member
Website: http://www.lrgwood.com
Use a water trap. Make sure its as far away from the compressor as possible. Your copper lines should be tipped back towards the compressor so any water will run back. Have your outputs higher up than the line itself to keep the liquid water that condensates in the line from pouring into your outputs.
Water Traps
3/20/13       #4: Water in Air Compressor lines ...
Snaglpuss
Put on an automatic drain valve.
How big is our system?
Add an air dryer.
Even places like Harbor Freight are selling small refrigerated air dryers.
3/31/13       #5: Water in Air Compressor lines ...
Water is hard on your air tools and a disaster when finishing. I you decide to do the home made thing with copper tube, buy some fintube units from a heating supplier. They are used on hot water heating systems. The aluminum fins greatly increase the heat exchange rate. If your air usage is moderate you can install a desiccant drier after the air to air unit. You could also self fabricate one. After the desiccant has been saturated (color change) you can spread it on a pan in your wife's oven and dry it back down. It can be used many times before it turns to dust. We have a large air to air cooler, refrigerated drier and then a desiccant drier just ahead of our expensive CNC equipment. At the paint booth we also have a coalescing filter designed to trap any oil that may come from the compressor. Yes it all adds to cost but so does the alternative.
