Dust Collection
Blow out dust bags
9/26/14
Tadhg
I have a 2 bag powermatic dust bag collection in my shop it's only year and half old recently the plastic bags are busting with holes an hour or two after replacing I checked for splinters but after checking machine it seems that bags are under far more suction pressure than usual. Has any one else had this problem thanks tadhg
9/29/14       #2: Blow out dust bags ...
JR Rutter Member
Sounds like your filters are clogging up.
12/3/14       #3: Blow out dust bags ...
Scott Peterson Member
Yes, your bags are probably clogged with fine dust. I have a large Dustek unit with 15 hp and 4 big plastic bags. When the cloth bags get plugged with dust, the plastic bags split and leak. This is worse in summer when it it hot.
You can restore some performance by shaking the bags, or blowing them off from the outside to the inside. Make sure the blower fan is off and not spinning when you are doing this cleaning (unplug or lock out). You will be surprised how much better your collector works with clean bags. If it keeps happening, get new or better cloth bags. Of course you are using good quality plastic bags too, right?
10/7/19       #4: Blow out dust bags ...
CleanAir707 Member
I'd suggest getting some better quality bags or upgrading to a cartridge/canister.
You don't want to inhale that dust if you're bags are spilling.
