Dust Collection
How to deal with static build-up???
2/19/15
JeffD
So this is my first winter in my new shop. In my old shop I never had much trouble with static electricity, just the occasional bit here and there. In my new place however I'm finding I get a lot of build-up in certain places and trying to figure out how to deal with it. The 2 biggest culprits seem to be the jointer and dust collector and I think the problem could be linked.
When I do a fair amount of jointing I start getting frequent zaps through the jointer in-feed table. I tired running a separate ground from the table to the receptacle box, but no help.
I believe the problem could be created by my dust bags. Due to the layout of the shop they are in the only place I could really fit them easily, (the size of the plenum and bags is roughly 30"D x 10'L x 11' H or so). But they are up against a roll-up door which leads to the neighboring shop. I think the aluminum door being so close to the bags, (4-5" or so), must be creating the build-up? But I have no idea short of re-arranging the entire shop how to fix it? I tried running a ground wire from the door the the nearest electrical box but no help. The jointer in-feed table is right next to the last bag and door so could be somehow picking up the static and transferring it? Or maybe they are 2 completely separate problems? Either way I'm curious if any of you have had to deal with excessive static electricity and how you dealt with it? Or any ideas for reducing the build-up between bags and door?
thanks,
JeffD
2/22/15       #2: How to deal with static build-up??? ...
Brent Member
Is it possible that the machine or associated receptacles have poor ground connections? Measuring from your machine to the ground wire leaving the receptacle the resistance should be less than one ohm.
2/22/15       #3: How to deal with static build-up??? ...
JeffD
Thanks for the reply Brent. I'm sure the receptacles are good as everything is new right to the panel. I'll have to double check the ground wire on the jointer and make sure it didn't get loose. But even when I added the additional wire from the table to the receptacle box there was no real difference.
JeffD
2/23/15       #4: How to deal with static build-up??? ...
Gary
What is the humidity level in your shop? Running a humidifier will help and possibly benefit in other ways as well.
2/23/15       #5: How to deal with static build-up??? ...
Jim Herron
Can you drill thru the slab and drive down a couple of 8' copper ground rods and ground the DC and jointer?
2/25/15       #6: How to deal with static build-up??? ...
JeffD
So I checked the machines/receptacles in question and the resistance checks out fine. I am wondering now how would one go about checking to see how well the panel is grounded? Is this something I could test, or would I need to open the wallet again and have the electrician to come back? Everything from the panel out is pretty much new now, however the panel and supply wiring is original.
I'm not opposed to installing grounding rods, though I'd rather add one outside and run the wiring through.. It's a rented space and without boring everyone with a lot of detail, it would just be easier to do it this way than drilling holes in the floor.
thanks,
Jeff
2/25/15       #7: How to deal with static build-up??? ...
cabinetmaker
Call the power company and ask them to check the lugs @ the meter. Get an electrician to check the lugs coming in. I had a loose neutral from the utility side and loose ground on the inside of a main discconect. That solved all of it
