Dust Collection
2HP cyclone dust collector
4/1/15
alex vargas Member
I have a Torit 2HP cyclone dust collector, i would like to install it in my shop, anybody could tell me if I can use for multiple machines? thanks.
4/1/15       #2: 2HP cyclone dust collector ...
You could probably run 6 machines on it, if they are all really close together and the thickness planer isn't over 15" wide. Your question is just too vague for anyone to tell you much more.
4/2/15       #3: 2HP cyclone dust collector ...
alex vargas
you right about that, i have a table saw, a shaper, and a 16" planer, the further one would be the planer, about 20 ft.
only me in the shop, and maybe in the future add one more shaper.
another question is do you think this machine could be upgrade with a more powerfull motor?
thanks
4/2/15       #4: 2HP cyclone dust collector ...
Curt Corum Member
Alex,
Please see attachments. Looks like the 2 HP cyclone does not have a 3 HP option. With the 20 foot main pipe, CFM delivery should be around 800.
Torit_Dust_Collector.pdf
4/10/15       #5: 2HP cyclone dust collector ...
Ken Member
Torit model 19 is the 2hp cyclone. The 3 & 5 hp had a 8" inlet and a 10" outlet. check yours, the 2hp had a 6" & 8". That said, you'll need to keep the main at 6" to maintain 800 cfm all the way to the machine and then you better keep your runs short and only one machine at a time. Changing your motor would not have any affect. Your motor is 2 hp turning 3500rpm. A 3 or 5 hp motor turns at, guess what? 3500rpm. Your fan will be turning the exact same speed. To take advantage of a larger motor you need a larger fan and larger inlet/outlets.
Torit_2.pdf
Air Handling Design Guide
4/10/15       #6: 2HP cyclone dust collector ...
alex vargas
good advise, thanks.
4/10/15       #7: 2HP cyclone dust collector ...
Ken Member
Alex, typically the way you design your system is from the machines back to the collector. To make it easy, let's say you're a one man shop and will only be using one machine at a time. You take the machine with the largest cfm requirements, let's say the 16" planer, looking at the pdf I linked to at Air Handling Systems, you see you should have a velocity of 4000fpm at the machine port. With a 6" port that's 785cfm to maintain that velocity. Then you start calculating all the ductwork to get back to the collector, 90s,45s, straight pipe to determine the static pressure (or look at it as resistance), then look at a fan curve chart (which Torit doesn't supply, only a range on my last attachment), to see if at that static pressure if the collector can move at lease 785cfm. If you had two machines running at the same time with 6" ports you would have to be moving 1570cfm at the collector. Of course if your trying to move 1570cfm you're not going to be moving it through a 6" main, you would have to bump that up to a 9". And on it goes.
4/13/15       #8: 2HP cyclone dust collector ...
Curt Corum
Website: http://airhand.com
Ken, Super replies on both accounts. The Torit info I have attached above has a more detailed performance chart for the 2,3, and 5 HP cyclone. Gives you a pretty good range of CFM deliveries at various levels of resistance. Some years ago I sold the Torit equipment. Had this data in my 3 ring binder.
Curt
