Dust Collection
Dust collector placement?
9/29/15
I've acquired a new/used outdoor baghouse for my new building next year. Any rules of thumb for how far from the building the unit should be placed? I'm in Minnesota, so the further from the shop it is the more the air is going to be cooled when it's -30º outside. I didn't get any literature with the unit and other than here I'm not sure where to turn to find such information.
10/1/15       #2: Dust collector placement? ...
Curt Corum
Karl, It really has to do with ducting it properly. Many times the bag house is installed on the pad too close to the building. Generally the exit pipe elevation and the bag house inlet are at a different heights and offset from one another. If too close, very short radius elbows will be necessary and will kill the air flow. You want to map it out using elbows that have a minimum of 1 1/2 x diameter centerline radius. The overall sweep of such elbow is 2 x diameter plus 2". If you squared a 14" 90 against the wall and floor and measured top to bottom, overall sweep would be 30". A 2x diameter centerline elbow would be overall of 37". This is where problems can arise. Also, if you need abort gate on the return, you have to allow for proper elbows and that device as well.
Curt
