Dust Collection
cleaning trunnions
3/22/16
Art Tinginys Member
I have a delta 10 inch contractors saw. When I raise the blade it squeaks .I have cleaned the gears with varsol and and also with lacquer thinner..it is much better but not perfect. Any suggestions?
3/23/16       #2: cleaning trunnions ...
Jim Herron
Kerosene followed by some Marvel Mystery Oil. Regular light application should keep it gunk free and moving smoothly.The oil has a slight solvent property to it to clean as well.
Hit the tilt and elevation gears as well.
Also the trunnions and elevator gears on a Uni have a space where dust can get mechanically compacted- be sure it's cleared before cleaning/lubricating.
Might require a pick or bent wire to loosen iit up.
3/23/16       #3: cleaning trunnions ...
Art Tinginys Member
Thanks ..who sells Marvel Mystery Oil?
3/27/16       #4: cleaning trunnions ...
Mitch Suber  Member
Website: subercustomshutters.com
I have seen Marvel Mystery Oil in auto parts stores, and also in automotive areas at Wal Mart. It is often sold as a "fix all repair oil", if I remember correctly, similar to items that fix transmissions or quiets valves, that sort of thing. Actually I once kept adding small amounts to a compressor that was knocking badly, dang thing ran for months beyond that point. It didn't fix anything, but it ran much smoother. Interesting stuff.
3/28/16       #5: cleaning trunnions ...
Use a dry lubricant. Paste wax or some of the graphite sprays. Anything that stays wet will just attract dust and make it cake onto the trunnion.
4/1/16       #6: cleaning trunnions ...
Art Tinginys
I solved my squealing saw elevation by flipping the table saw over and lubricating the elevating screw bushing area. The trunnions were not the problem.
