Dust Collection
Heat
3/7/19
What is the best way to heat a smaller shop. I have switched to propane from kerosene.
3/8/19       #2: Heat ...
Larry,
What size of shop are talking about? What is the building type/construction.
Where are you situated compared to utilities?
There are a lot of unknowns, but generally the most efficient way to heat a building is with natural gas, it is cheap and burns clean. There are a lot of appliances that can be used with natural gas, all the way from your smallest unit heater to your largest make up air units and then there are options like radiant tube heaters, furnaces, boilers for hot water heating with a variety of heat exchanger options.
There is also the option of electrical heat if the area is small, it is generally more expensive than natural gas.
Another option is wood, again there are wood boilers away from the building or wood furnaces or wood stoves in the building. Where I am located some insurance companies frown on having a wood burning appliance in a wood shop, something you would have to check out.
Propane can be used just like natural gas, it is generally more expensive than natural gas and you require a storage tank for it nearby. You can use a furnace or a unit heater, make up air unit, but the appliance has to be approved for propane as the burner orfaces are a different size.
All heat methods of course require the proper venting so you don't fill up your building with carbon monoxide.
3/8/19       #3: Heat ...
BH Davis  Member
There is no "best system" for all small shops. There is only the best system for your given situation.
Propane is a good step up from kerosene assuming that you are going from an unvented kerosene unit to a vented propane unit.
Instead of telling you what is the best system I would tell you what to avoid. That would be any unvented system and any heat source, vented or unvented, that uses indoor shop air for combustion. Wood dust is explosive and should never be exposed to open flame.
3/8/19       #4: Heat ...
I think in floor radiant with a NG boiler is the most cost effective and comfortable way to heat a woodshop.
3/9/19       #5: Heat ...
In floor sounds nice. We are drilling holes in the floor constantly. That would scare the hell out of me.
3/9/19       #6: Heat ...
My slab is 6" thick, the pipe for the heat is stapled to the foam insulation under the slab. You just don't drill all the way through, and when you abandon pins in the floor, you cut them off instead of pounding them in.
I get squeamish drilling holes in the floor though, but most anchors don't have to go terribly deep to do their job. The only thing I'm concerned about is a pipe not being where it's supposed to be and being too close to the surface.
The heat is outstanding, it keeps everything warm. Material, equipment, feet. Recovering time from doors being opened is surprisingly quick. My little shop has almost 600k pounds of concrete in the floor, once the floor is up to temp, there isn't much fluctuation.
Plus there's no air being handled or heating equipment being affected by dust. I wouldn't heat a woodshop any other way unless heat wasn't needed often. I'm in Minnesota, it runs almost 5 months a year.
3/10/19       #7: Heat ...
David Egnoski  Member
Website: http://www.richmondcabinet.com
You can pretty easily see the tubing in the floor with an infrared gun. My heating guy located tubing for me.
Best heat source for my shop.
3/12/19       #8: Heat ...
On a professional site like this one, a smaller shop could mean 10,000 square feet to some. You might want to narrow it down a little.
    • GreCon
    • RT Machine Co.
    • Denray Machine
    • American Fabric Filter Co.
    • Sandman Products
    • Air Handling Systems
