Dust Collection
Shaper loosing power
6/4/20
Tadhg
Hi guys I have a Powermatic 2700 Shaper it runs on 240 v On a dedicated line and when we run material through it the machine starts loose power as if it was shut off. It doesn’t seem make difference on type of bits we install.Big or small And we have keep hitting green button to keep machine running has anyone had this type of problem thanks tadhg
6/5/20       #2: Shaper loosing power ...
I assume you have a magnetic starter. Inside the starter is a dial that determines when the overload protection trips. Usually it has some numbers on it relating to amps. Depending on the size of the protector circuit will depend on the numbers shown on the dial.
Usually when it comes from the factory they are set with pretty tight tolerances. I've had some where they were fine and others that tripped to easily.
Turn the dial up a bit, maybe 3 or 4 amps and see if that solves the problem.
6/5/20       #3: Shaper loosing power ...
Or the magnetic starter is failing. Either broken/mis-made parts, or a chunk of crap in there. Pop the face off and blow it out.
Sometimes you have to take the mag starter apart and wipe things off. It doesn't take much sometimes to screw up the works if it's sensitive.
6/11/20       #4: Shaper loosing power ...
So what became of this?
7/12/20       #5: Shaper loosing power ...
Tadhg
Hi guys sorry for very late reply I removed Start coverSwitch and blew out with air. Then I checked electric connections supplying power to machine. Especially wire nuts holding Separate wires together I turned them half notch each Tight And I had no more problems since. Running perfect thanks tadhg
7/12/20       #6: Shaper loosing power ...
Dust in the system. Happens all the time.
    • GreCon
    • RT Machine Co.
    • Denray Machine
    • American Fabric Filter Co.
    • Sandman Products
    • Air Handling Systems
