Dust Collection
shop flooring
7/16/20
bobbywood Member
I am building a 2 story woodworking shop.
Cement floor on the lower level will have the machinery. What do you recommend for the second floor. it is a wood framed building, and the builder will install advantec sub floor. should I just use this, maybe paint it, or install vinyl or wood on top. second floor for bench work, assembly and finishing.
7/17/20       #2: shop flooring ...
Unfinished fir plywood. Vinyl tile gets very slippery with saw dust.
7/19/20       #3: shop flooring ...
I would put some kind of protection on top of your subfloor, even a 1/4 or 1/2 in sanded one side plywood screwed down with no adhesive. A work shop floor takes a lot of abuse, over time it will wear, you spill stuff like adhesives or stains. With a covering later you can easily replace a piece if required, replacing tongue and groove subfloor glued down is quite a task.
Are you limited on space? I am just wondering why you chose to build a shop like that? It is very inefficient, all the material has to go up, all the finished product has to come down, every time you need to cut a little or sand a little, you and your piece have to come down and then back up, didn’t quite take enough off, back down and up.
7/28/20       #4: shop flooring ...
Snaglpuss
First shop I worked in had wood floors. Very nice. It also was 4 story with elevator. That sucked big time.
8/1/20       #5: shop flooring ...
BH Davis  Member
I've always had good success with simple particle board floors. They don't delaminate when you drag heavy items across them the way plywood can. Once down and painted gray you have to look twice to notice they aren't concrete.
Inexpensive, easy to put down, hold paint well and extremely durable. I've done this in numerous shops over the years.
    • American Fabric Filter Co.
    • Sandman Products
    • Air Handling Systems
    • Denray Machine
    • RT Machine Co.
    • GreCon
