Dust Collection
NFPA 664
3/11/22
Tim Mowry  Member
Website: http://www.hrmillwork.com
Hello All,
We've recently survived (mostly) a OSHA inspection but one of the violations sited was we have an enclosureless dust collector connected to woodworking machinery with power feeds - specifically a planer, drum sander and molder in violation of NFPA 664. Personally, I'm wasn't of this regulation as I suspect 99% of smaller shop owners are not as well. Anyone else come across this situation? The DC involved is a 5HP single stage dual bag system. I don't think the solution is as simple as putting a box around the DC. Thoughts/comments please?
Thanks,
Tim
3/11/22       #2: NFPA 664 ...
I just read through some articles meant to explain the code and the responsibilities of owners of wood processing facilities. I don't think the code requires that a dust collector be enclosed in a separate space. The collector and ducting is in itself an enclosed system. You may have a problem with plastic ductwork but the language seems vague about it.
Did the inspector have issue with a build up of fine dust above 1/8" thickness? This would constitute an explosion hazard. Did he/she require you to do a dust hazard assessment (DHA)? From my reading which is cursory, it looks like your DC is fine. But you will have to take care of any escaping fine dust that could build up in the shop.
I wonder whether your OSHA inspector misunderstood the language around dust conveyor systems and assumed it meant power feed systems for machinery.
3/16/22       #3: NFPA 664 ...
Tim Mowry  Member
Thanks Tom. Any links you found on the subject would be very helpful. The inspector did have issue with continuity between machines and DC but that's easily handled with a ground wire I believe. They did not require a DHA.
Tim
4/10/22       #4: NFPA 664 ...
cabinetmaker
We had lots of walk throughs in our shop Fire, insurance, insurance consultants, etc.
A lot of times it’s interpretation of the cited regulation. Our big dust collectors are outside but small bagged units are inside.
What they are seeing is the Georgia sugarcane explosion in front of them laid out. Open motors, bearings, surface dust and a flash fire that could be catastrophic. The enclosure of said unit and fire dampers could keep it to a small roar
Source and prevention of ignition is a big, big concern Read NFPA 664 and it’s pointing toward the owners responsibility to prevent ignition with a design that minimizes the threat of one.
The reality is housekeeping, flammable storage, egress, lighting and up to date extinguishers with good labeling.
How many minutes could an enclosed room of flame resistant mdf or two layers of rock give you to get out if you had a fire in the dust collector ? Could you build a room/closet with a damper on a fusible link that would cut off oxygen to the room. Could you put a ceiling extinguisher up there that could spread retardant ?
We just changed carriers and the pictures they took that they wanted corrective action were alarming and embarrassing. Our shop had never looked that, but it did on the day they took the pictures. We now have pictures posted how an area must look at all times.
Unfortunately as the owner I have to slow up the shop and pay for housekeeping.
We just had a tornado talk and where to go in such emergency. If I buy the building we will be building a rated shelter in the building
4/10/22       #5: NFPA 664 ...
cabinetmaker
https://www.grainger.com/product/DAYTON-Fire-Damper-2TFZ5?opr=PDPRRDSP&analyti
cs=dsrrItems_2TFZ7
    • American Fabric Filter Co.
    • Sandman Products
    • Air Handling Systems
    • Denray Machine
    • RT Machine Co.
    • GreCon
